[Mapserver-users] Problem with tiled raster data and ms4
Dylan Keon
keon at nacse.org
Mon Jan 5 11:30:12 EST 2004
There were many changes between 3.6 and 4.0. Be sure to read the 4.0
Migration Guide in the Wiki -
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MigrationGuide .
For example, OFFSITE now expects an RGB value instead of a color index
value. If you're using OFFSITE on your tiled raster layer, that could
be your problem (maybe).
The Wiki page includes more examples.
--Dylan
On 01/05/2004 08:18 AM Steffen Bittner wrote:
> Dear list,
> I'm using MapServer under win2000 with apache 1.3.27.
> After upgrading from ms 3.6 to 4.0 I have the problem that ms does not draw
> tiled raster data anymore.
> When I access a tiled raster layer I get no result from the web server. In
> the task manager I see the mapserv-process, but no result will be delivered to
> the client. I get no result or error message until I stop the
> apache-service.
> The same problem I experience when I access the layer using mapscript (then
> I see php.exe in the task manager as long as I do not
> terminate the apache-service).
> There are no errors logged in the MapServer log and no error messages in the
> apache log.
> When I use mapserv with my Query included in the "QUERY_STRING=" Parameter I
> get the correct result - the http-content I expect written to stdout. When I
> use shp2img I get the correct image.
> When I set the environment variable MS_ERRORFILE in my http.conf (pointing
> to some file)
> it only contains the message "msBuildPath: Unable to access file."
> When I use apache 2.0.48 anything works fine.
> Can anybody give me a hint? Where is my mistake? Does ms4 have a problem
> with apache 1.3.x?
> Thanks in advance for your help.
> Steffen Bittner
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dylan Keon - GIS/Database Specialist
Northwest Alliance for Computational Science and Engineering
Oregon State University
Corvallis, OR 97331
keon at nacse.org voice: 541-737-6608 fax: 541-737-6609
