[Mapserver-users] Mapserver 401: Reference image bounding
box
David Fawcett
David.Fawcett at state.mn.us
Tue Jan 6 10:03:45 EST 2004
Heryk,
Is the bounding box missing at all scales, or just at full extent. In other words, try zooming in on your primary image, does a complete or partial bounding box appear?
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> "Julien, Heryk" <hjulien at nrcan.gc.ca> 1/6/2004 8:39:16 AM >>>
I checked the image size and everything is okay. The base reference image is
a gif which measures 175 by 117 pix. The outputted gif reference image is
the same size but the bounding box is missing!
Still trying to debug the reference image.
Thanks for the reply
Bedankt
Héryk
Mapfile:
REFERENCE
COLOR 255 0 0
EXTENT 493163 4857827 2100223 5910452
STATUS ON
OUTLINECOLOR 255 0 0
SIZE 175 117
IMAGE "..\data\raster\refQcMaritimesUTM83Z18.gif"
END #REFERENCE
-----Message d'origine-----
De : Till Adams [mailto:adams at terrestris.de]
Envoyé : Tuesday, January 06, 2004 3:35 AM
À : Julien, Heryk
Cc : mapserverlist
Objet : Re: [Mapserver-users] Mapserver 401: Reference image bounding
box
Julien,
I had this problem before - your image used for the reference map might
have a higher resolution than the defined box in your clinet - e.g. the
image has 600 x 400 pix and in your client you defined the reference map
to have 140 x 100 pix: Mapserver scales the image down to 150 x 100 pix
(also leading to performance loss) and with it the (red) bounding box,
which has 1 pixel linewidth.
Cheers,
Till
Julien, Heryk schrieb:
> Hi,
> Anyone else having trouble or found a solution to the reference image
> "bounding box" not being drawn?
> I selected a red bounding box (outlinecolor 255 0 0) in my mapfile but it
is
> not showing up on the reference image!
> I'm using Mapserver 401.
> Héryk
> NRCan
>>De : Julien, Heryk
>>Envoyé : Thursday, December 18, 2003 2:28 PM
>>À : 'mapserver-users at lists.gis.umn.edu'
>>Objet : reference image bounding box
>>Hi,
>>I'm having trouble with my reference image bounding box. The reference
>>image appears and I can navigate in my map by clicking in the reference
>>image however the bounding box doesn't display in the reference image.
>>Anyone had that trouble before?
>>Mapfile:
>># Start of reference map
>>REFERENCE
>> COLOR -1 -1 -1
>> STATUS ON
>> SIZE 175 117
>>END #REFERENCE
>>Héryk
>>NRCan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
NEU +++ NEU +++ NEU +++ NEU
AveiN! ist Open Source
Lizensiert unter der GNU GPL
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
