[Mapserver-users] Mapserver 401: Reference image bounding box
Eric Bridger
eric at gomoos.org
Tue Jan 6 10:03:18 EST 2004
What size is your map? Does the map aspect ratio match 175/117?
On Tue, 2004-01-06 at 09:39, Julien, Heryk wrote:
> Hi,
> I checked the image size and everything is okay. The base reference image is
> a gif which measures 175 by 117 pix. The outputted gif reference image is
> the same size but the bounding box is missing!
> Still trying to debug the reference image.
> Thanks for the reply
> Bedankt
> Héryk
> Mapfile:
> REFERENCE
> COLOR 255 0 0
> EXTENT 493163 4857827 2100223 5910452
> STATUS ON
> OUTLINECOLOR 255 0 0
> SIZE 175 117
> IMAGE "..\data\raster\refQcMaritimesUTM83Z18.gif"
> END #REFERENCE
> -----Message d'origine-----
> De : Till Adams [mailto:adams at terrestris.de]
> Envoyé : Tuesday, January 06, 2004 3:35 AM
> À : Julien, Heryk
> Cc : mapserverlist
> Objet : Re: [Mapserver-users] Mapserver 401: Reference image bounding
> box
> Julien,
> I had this problem before - your image used for the reference map might
> have a higher resolution than the defined box in your clinet - e.g. the
> image has 600 x 400 pix and in your client you defined the reference map
> to have 140 x 100 pix: Mapserver scales the image down to 150 x 100 pix
> (also leading to performance loss) and with it the (red) bounding box,
> which has 1 pixel linewidth.
> Cheers,
> Till
> Julien, Heryk schrieb:
> > Hi,
> > Anyone else having trouble or found a solution to the reference image
> > "bounding box" not being drawn?
> > I selected a red bounding box (outlinecolor 255 0 0) in my mapfile but it
> is
> > not showing up on the reference image!
> > I'm using Mapserver 401.
> > Héryk
> > NRCan
> >>De : Julien, Heryk
> >>Envoyé : Thursday, December 18, 2003 2:28 PM
> >>À : 'mapserver-users at lists.gis.umn.edu'
> >>Objet : reference image bounding box
> >>Hi,
> >>I'm having trouble with my reference image bounding box. The reference
> >>image appears and I can navigate in my map by clicking in the reference
> >>image however the bounding box doesn't display in the reference image.
> >>Anyone had that trouble before?
> >>Mapfile:
> >># Start of reference map
> >>REFERENCE
> >> COLOR -1 -1 -1
> >> STATUS ON
> >> SIZE 175 117
> >>END #REFERENCE
> >>Héryk
> >>NRCan
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> NEU +++ NEU +++ NEU +++ NEU
> AveiN! ist Open Source
> Lizensiert unter der GNU GPL
> Dipl. Geogr. Till Adams
> terrestris, Paulsen&Adams GbR
> Siemensstr. 8 * 53121 Bonn
> Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
> info at terrestris.de * www.terrestris.de
