[Mapserver-users] PHP MapScript DLL QueryMap class?
Daniel Morissette
morissette at dmsolutions.ca
Wed Jan 7 00:15:14 EST 2004
Mike Leahy wrote:
> I see there are PHP MapScript constants defined for the QueryMap object
> (i.e. the Querymap styles), but there is no way to change anything in the
> querymap. This is not a particularly huge deal, as I already have a
> workaround in my case, but it might be a little more efficient if a class
> was defined that provided access to those parameters from a PHP script. Is
> this something we might see in later builds...or is there an undocumented
> class or function that can be used?
You're correct: there is no way to set members of the QueryMap object
via PHP MapScript. I have created a bug about this so that we don't
forget to add it eventually:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=535
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
