[Mapserver-users] 500 Server Error - Log: Premature end of script
headers
Till Adams
adams at terrestris.de
Wed Jan 7 08:47:07 EST 2004
Dear Eric,
I guess it's the same problem, we ran in several month ago - I've
posted the following some days ago to another person, dealing with the
same problem:
I guess you have to re-read your ld.so.conf table, probably you'll find
it in /etc. Apache does not find all the required librares for running umn.
There are two ways to go:
1. Edit the file ld.so.conf and add the line
/usr/lib
Then restart your server or run '/sbin/ldconfig'
2.
Run the command
'/sbin/ldconfig /usr/local'
(Both as 'root')
If you choose way 2 please remember, that you'll have to give this
command every time you restart your server.
Hope that helps
Till
Eric Pocher schrieb:
> Hi All,
> i complied the mapserver successfully. if I execute the file in the shell I
> get the message:
> "This script can only be used to decode from results and should be initiated
> as a CGI process via a httpd server."
> So I think the mapserv-file is allright. but if I open the file from a
> browser directly without any parameters, I should get the message "No query
> information to decode. QUERY_STRING not set.", but the 500 INERNAL SERVER
> ERROR returned.
> The logfile says:
> "Premature end of script headers."
> Is there any error in the mapserv-file or in the conig of the webserver.
> Server OS: Suse Linux 8
> Webserver: Apache 1.3
> Eric
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
NEU +++ NEU +++ NEU +++ NEU
AveiN! ist Open Source
Lizensiert unter der GNU GPL
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
