[Mapserver-users] 500 Server Error - Log: Premature end of script
headers
Oliver Wesp
wesp at gdv.com
Wed Jan 7 08:13:40 EST 2004
Eric,
most likely there is no LD_LIBRARY_PATH set within your apache
environment and therefore mapserv doesnt't find the necessary libs when
invoked via cgi.
Try adding something like
setenv LD_LIBRARY_PATH /usr/local/lib
to your httpd.conf and restart apache.
best regards
Oliver
Try something
Eric Pocher wrote:
> Hi All,
> i complied the mapserver successfully. if I execute the file in the shell I
> get the message:
> "This script can only be used to decode from results and should be initiated
> as a CGI process via a httpd server."
> So I think the mapserv-file is allright. but if I open the file from a
> browser directly without any parameters, I should get the message "No query
> information to decode. QUERY_STRING not set.", but the 500 INERNAL SERVER
> ERROR returned.
> The logfile says:
> "Premature end of script headers."
> Is there any error in the mapserv-file or in the conig of the webserver.
> Server OS: Suse Linux 8
> Webserver: Apache 1.3
> Eric
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dipl.-Geogr. Oliver Wesp
Gesellschaft fuer geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
