[Mapserver-users] mapserv 4.0 CGI misbehaving on IIS but working on Apache 2.0.48
Martin, Daniel A
Daniel.A.Martin at erac.com
Wed Jan 7 11:59:14 EST 2004
This usually means the dll library files are not available in the path. The easiest solution is to copy all the dll files to C:\WINNT\System32, but anywhere in the path will do.
-Dan
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> nicolas.fortin at ec.gc.ca
> Sent: Wednesday, January 07, 2004 10:39 AM
> To: wim.blanken at planet.nl; mapserver-users at lists.gis.umn.edu
> Subject: RE : [Mapserver-users] mapserv 4.0 CGI misbehaving
> Hi,
> I already stumble on this problem. It's probably a
> permission problem with the IUSR_ user(Web Anonymus User).
> You chould begin by giving IUSR_ access to the [ORA_HOME]/bin
> directory (more specific to [ORA_HOME]\bin\OCI.dll)
> If it's doesn't work, I'll try to find the docu I write on
> the problem. You could also use filemon.exe from sysinternal
> to find the access problem yourself and easily.
> Hope this helps
> Nick
> -----Message d'origine-----
> De : Wim Blanken (PI) [mailto:wim.blanken at planet.nl]
> Envoyé : Wednesday, January 07, 2004 11:10 AM
> À : mapserver-users at lists.gis.umn.edu
> Objet : [Mapserver-users] mapserv 4.0 CGI misbehaving on IIS
> Hello List,
> Strange problem today,
> I installed an application created using binary mapserver 4.0
> (oracle/png) cgi-version on a fresh install of windows 2000
> server that had oracle 9 installed.
> The application tells me in clear english, the cgi had
> misbehaved and returned no headers. I tested this before with
> the same application on another server and then there was no
> problem. On the same machine there is also no problem with
> mapserv -v and it worked OK on the same machine when I used
> Apache instead of IIS. I also tried rebooting and copying all
> the dll's but no luck...... All the dll's are in place
> (apache can also find them so that should not be the
> problem). Looked at the rights in IIS and for so far I can
> see all the rights are OK.
> Has anybody a clue why this applic is running on apache but
> not on iis on the same server?
> Sincerely
> W. Blanken
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
