[Mapserver-users] mapserv 4.0 CGI misbehaving on IIS but wor
king on Apache 2.0.48
nicolas.fortin at ec.gc.ca
Wed Jan 7 11:39:12 EST 2004
I already stumble on this problem. It's probably a permission problem with
the IUSR_ user(Web Anonymus User).
You chould begin by giving IUSR_ access to the [ORA_HOME]/bin directory
(more specific to [ORA_HOME]\bin\OCI.dll)
If it's doesn't work, I'll try to find the docu I write on the problem.
You could also use filemon.exe from sysinternal to find the access problem
yourself and easily.
Hope this helps
Nick
-----Message d'origine-----
De : Wim Blanken (PI) [mailto:wim.blanken at planet.nl]
Envoyé : Wednesday, January 07, 2004 11:10 AM
À : mapserver-users at lists.gis.umn.edu
Objet : [Mapserver-users] mapserv 4.0 CGI misbehaving on IIS but working on
Apache 2.0.48
Hello List,
Strange problem today,
I installed an application created using binary mapserver 4.0 (oracle/png)
cgi-version on
a fresh install of windows 2000 server that had oracle 9 installed.
The application tells me in clear english, the cgi had misbehaved and
returned no headers.
I tested this before with the same application on another server and then
there was no problem.
On the same machine there is also no problem with mapserv -v and it worked
OK on the same machine when I used Apache instead of IIS.
I also tried rebooting and copying all the dll's but no luck......
All the dll's are in place (apache can also find them so that should not be
the problem).
Looked at the rights in IIS and for so far I can see all the rights are OK.
Has anybody a clue why this applic is running on apache but not on iis on
the same server?
Sincerely
W. Blanken
