[Mapserver-users] mapserv 4.0 CGI misbehaving on IIS but working on Apache 2.0.48
Wim Blanken PI
wim.blanken at planet.nl
Wed Jan 7 11:09:47 EST 2004
This is a multi-part message in MIME format.
--Boundary_(ID_vemGPiu2QxnAkRDU5aug+w)
Content-type: text/plain; charset=iso-8859-1
Content-transfer-encoding: 7BIT
Hello List,
Strange problem today,
I installed an application created using binary mapserver 4.0 (oracle/png) cgi-version on
a fresh install of windows 2000 server that had oracle 9 installed.
The application tells me in clear english, the cgi had misbehaved and returned no headers.
I tested this before with the same application on another server and then there was no problem.
On the same machine there is also no problem with mapserv -v and it worked
OK on the same machine when I used Apache instead of IIS.
I also tried rebooting and copying all the dll's but no luck......
All the dll's are in place (apache can also find them so that should not be the problem).
Looked at the rights in IIS and for so far I can see all the rights are OK.
Has anybody a clue why this applic is running on apache but not on iis on the same server?
Sincerely
W. Blanken
Content-type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 5.50.4134.600" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>Hello List,</FONT></DIV>
<DIV><FONT face=Arial size=2></FONT> </DIV>
<DIV><FONT face=Arial size=2>Strange problem today,</FONT></DIV>
<DIV><FONT face=Arial size=2>I installed an application created using binary
mapserver 4.0 (oracle/png) cgi-version on</FONT></DIV>
<DIV><FONT face=Arial size=2>a fresh install of windows 2000 server that had
oracle 9 installed. </FONT></DIV>
<DIV><FONT face=Arial size=2>The application tells me in clear english, the cgi
had misbehaved and returned no headers.</FONT></DIV>
<DIV><FONT face=Arial size=2>I tested this before with the same application on
another server and then there was no problem.</FONT></DIV>
<DIV><FONT face=Arial size=2>On the same machine there is also no problem with
mapserv -v and it worked</FONT></DIV>
<DIV><FONT face=Arial size=2>OK on the same machine when I used Apache instead
of IIS.</FONT></DIV>
<DIV><FONT face=Arial size=2>I also tried rebooting and copying all the dll's
but no luck......</FONT></DIV>
<DIV><FONT face=Arial size=2>All the dll's are in place (apache can also find
them so that should not be the problem).</FONT></DIV>
<DIV><FONT face=Arial size=2>Looked at the rights in IIS and for so far I can
see all the rights are OK.</FONT></DIV>
<DIV><FONT face=Arial size=2>Has anybody a clue why this applic is running on
apache but not on iis on the same server?</FONT></DIV>
<DIV><FONT face=Arial size=2>Sincerely</FONT></DIV>
<DIV><FONT face=Arial size=2>W. Blanken</FONT></DIV>
<DIV><FONT face=Arial size=2></FONT> </DIV></BODY></HTML>
--Boundary_(ID_vemGPiu2QxnAkRDU5aug+w)--
