R: R: [Mapserver-users] Mapinfo symbols
pxniw pxniw
pxniw69 at yahoo.com
Wed Jan 7 14:01:47 EST 2004
You could use condition statement. found here
http://www.maptools.org/chameleon/wiki/MapImageSharedResource
Create a condition and an image for all the angles you
need. (I would not do 360 conditions, but maybe 12 or
so, would get you started.)
Just a suggestion ;)
Not sure if I understood the question.
Px
--- Ballini Yvain <Ballini.Yvain at seat.it> wrote:
> Hi Julien and Daniel,
> Thank you for your suggestion and your help.
> We also are tryning to see in the source which
> enhancement could enable to manage the angles with
> truetype symbols.
> Keep in touch if someone has some suggestion.
> Best regards,
> Yvain.
> -----Messaggio originale-----
> Da: Julien-Samuel Lacroix
> [mailto:lacroix at dmsolutions.ca]
> Inviato: lunedì 5 gennaio 2004 22.10
> A: Ballini Yvain
> Cc: Daniel Morissette;
> mapserver-users at lists.gis.umn.edu
> Oggetto: Re: R: [Mapserver-users] Mapinfo symbols
> Hi Yvain,
> While checking your problem I noticed why angle is
> ignored with the STYLEITEM "AUTO" in your layer.
> It's because the angle is not supported for symbols.
> It's only supported for labels. So your arrows can't
> have the good angle. I opened two bugs for this 532
> and 533
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=532
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=533
> But I don't know when it will be fixed.
> A work around could be to use a font with symbol in
> it and put labels in your map that will be arrows.
> Then the angle will be used correctly.
> But there's certainly a better way to acheive what
> you want. Anybody on the list has a suggestion?
> Best regards,
> Julien
> Ballini Yvain wrote:
> > Hi Daniel,
> > I'm turning to the topic of the orientation of
> point symbol, do you know where I can find on the
> mapserver source the part which manages the symbols
> tuned by OGR. I would like to try to do some update
> on my mapsrver version to solve this problem.
> > Thanks a lot.
> > Yvain.
> > Da: Daniel Morissette
> [mailto:morissette at dmsolutions.ca]
> > Inviato: giovedì 18 dicembre 2003 0.43
> > A: Ballini Yvain
> > Cc: mapserver-users at lists.gis.umn.edu
> > Oggetto: Re: [Mapserver-users] Mapinfo symbols
> > Yvain,
> > Um, I checked the code and it seems that we ignore
> the angle value coming from STYLEITEM AUTO for point
> symbols. Could please you submit a bug with a small
> mapfile and arrow.tab to reproduce this? I'm not
> sure when we would have time to work on this, but
> with a testcase to reproduce it's always easier for
> us.
> > Thanks
> > Daniel
> >>Hi list,
> >>I would like to read the arrows of a .tab file in
> mapserver: the pb is
> >>that I can read the position but not the
> orientation of the arrow
> >>which is contained in the "Style" line of the .tab
> (see under).
> >>when I try to read my file arrow.tab with ogrinfo
> it turns me these
> >>properties for the arrow layer:
> >>Layer name: arrow
> >>Geometry: Point
> >>Feature Count: 267349
> >>Extent: (6.682870, 36.681040) - (18.495850,
> 46.895265) Layer SRS WKT:
> >>GEOGCS["unnamed",
> >> DATUM["WGS_1984",
> >> SPHEROID["WGS 84",6378137,298.257223563],
> >> TOWGS84[0,0,0,0,0,0,0]],
> >> PRIMEM["Greenwich",0],
> >> UNIT["degree",0.0174532925199433]]
> >>LABEL: String (70.0)
> >>OGRFeature(arrow):1
> >> LABEL (String) =
> >> Style =
>>SYMBOL(a:322,c:#4144ae,s:13pt,id:"mapinfo-sym-111.ogr-sym-1")
> >> POINT (8.85458500 45.96559000)
> >>OGRFeature(arrow):2
> >> LABEL (String) =
> >> Style =
> >>I define my arrow layer like that:
> >>LAYER
> >> NAME freccie_navtech
> >> PROJECTION
> >> "proj=longlat"
> >> "ellps=intl"
> >> "no_defs"
> >> END
> >> STATUS OFF
> >> DATA
> arrow#chiave_in_piazzale_segesta#arrow#vie3_polyline
> >> CONNECTIONTYPE OGR
> >> CONNECTION
>>"c:\mapserver\itasca\data\arrow.tab"#chiave_in_piazzale_segesta.tab"#a
> >>rr
> >>ow.tab"
> >> STYLEITEM "AUTO"
> >> TYPE point
> >> CLASS
> >> #STYLE
> >> # SYMBOL arrow
> >> # size 20
> >> COLOR 88 88 245
> >> #ANTIALIAS TRUE
> >> #END
> >> END
> >>END
> >>I think I can't recognize the id mapinfo-sym-111
> which represents the
> >>arrow...but the position of the default point
> symbol is right on the
> >>map.
> >>Does someone know something about this problem or
> if there is a
> >>setting in the mapfile which could solve my
> problem?
> >>Thanks a lot.
> >>Yvain.
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> DM Solutions Group
> http://www.dmsolutions.ca/
Do you Yahoo!?
Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
http://hotjobs.sweepstakes.yahoo.com/signingbonus
