[Mapserver-users] Layer Status in Map File
Andrew Arace
AArace at geonetics.com
Thu Jan 8 10:00:15 EST 2004
'Initializing' the map server by just sending a map=(path) CGI command
does not set the layers to the status defined in the .map file.
It seems to initialize the map (the first request) you must send a
minimum of map=(path)&layer=layer1&layer=layer2&...
So in other words, what is the point of the STATUS in the LAYER object
of the map file (aside from the DEFAULT, which is needed)
-Andrew
Andrew Arace
aarace at geonetics.com
Software Engineer
Geonetics, Inc
(617) 896 - 4409
Disclaimer Notice: This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute, or copy this e-mail. Please notify the sender immediately if you have received this e-mail by mistake and delete this e-mail from your system. E-mail transmission cannot be guaranteed to be secure or error free as information can be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message, which arise as a result of e-mail transmission. If verification is required please request a hard copy version. BSC Companies, Inc.; BSC Group, Inc.; Geonetics, Inc. 15 Elkins Street Boston, Massachusetts 02127 USA. www.BSCGroup.com.
http://www.bscgroup.com/
