[Mapserver-users] scaling rasters like ttf's (gif, jpg etc)
Sean Gillies
sgillies at frii.com
Thu Jan 8 10:10:30 EST 2004
On Jan 8, 2004, at 3:53 AM, <lists at atsence.nl> wrote:
> Hi all,
> I wonder if there is a way to scale gifs in a mapserver app. Like the
> a ttf location marker with php mapscript.
> We generatie a gif that represents a graph from a point location
> (local measurements.) We position the gif on the map by using
> (generating) an accompanying ..wld file.
> However by using it this way it will not scale with the zoom factor.
> Is there anohtee way to place the gif (png/jpeg that is not the
> problem) on a map so that it will scale like the ttf markers?
> Best regards,
> Bart
Bart,
Do I understand correctly that you have a point layer and want to use
an image as a symbol for the point? Do something like this
SYMBOL
NAME "symbol_point1"
TYPE PIXMAP
IMAGE path/to/generated/symbol.gif
END
LAYER
NAME "point1"
TYPE POINT
FEATURE
POINTS 100 100 END # Replace with true coordinates
END
SYMBOLSCALE 100000 # Scale at which symbol appears at the size below
CLASS
STYLE
SYMBOL "symbol_point1"
SIZE 64 # This is the size at scale of 1:10,000
END
MINSIZE 32 # Smallest size symbol will be drawn
MAXSIZE 128 # Largest size symbol will be drawn
END
END
This might be difficult if you have many points. I like your idea of
using the graph as a raster ... if the world file is correct, the
graph should zoom in and out just like the rest of the map.
Hope this helps,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
