[Mapserver-users] WMS BBOX vs. Actual Bounds
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Jan 8 12:25:15 EST 2004
Isn't this the one test which failed for the OGC conformance testing? IMHO,
we should try to fix this one.
..Tom
> -----Original Message-----
> From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
> Sent: Thursday, January 08, 2004 12:04 PM
> To: ian at geography.leeds.ac.uk;
> mapserver-users at lists.gis.umn.edu; ed at topozone.com
> Subject: RE: [Mapserver-users] WMS BBOX vs. Actual Bounds
> There was a bug filed way back regarding non-square pixels
> and there has been some progress in supporting this, but it
> has not been a high priority at all- most folks want square
> pixels. The work-around I mentioned yesterday is still quite
> reasonable and works well.
> Steve
> >>> "Ed McNierney" <ed at topozone.com> 1/8/2004 10:46:39 AM >>>
> Ian -
> If you have different scales in X and Y directions, the
> projection should reflect that. If the projection is not
> defined to have different scales, then asking for different
> scales is not consistent.
> If I ask for a 1,000-meter by 1,000-meter area in UTM
> projection in an image that's 300 pixels by 200 pixels, it's
> not possible to do all three. If I keep the area 1,000x1,000
> and stretch it to fit in 300x200 pixels, then the projection
> is no longer UTM. If I keep the area 1,000x1,000 and the
> projection UTM, I have to modify the image size and return
> something square - 300x300, for example. If I keep the
> projection UTM and the output image 300x200, then I have to
> modify the map area to something 1.5:1 - 1,500x1,000 meters,
> for example. MapServer, of course, chooses the last option,
> but I have a hard time seeing how any one of the three
> choices is the "right" answer.
> If you're creating output for a device with non-square
> pixels, it seems that the way to handle that would be to
> provide an additional input parameter to the WMS interface,
> describing the aspect ratio of the the pixels. This would
> still allow a client to make an inconsistent request, but it
> would allow requests intended for non-square pixels to be
> made consistent with the specified projection.
> However, you are absolutely correct that this is NOT how the
> WMS specification handles it. The specification does require
> the server to stretch the image to fit the box, thereby
> presuming that any inconsistency in the request is due to a
> careful client requesting an image for non-square pixels,
> rather than an error.
> I suppose support for non-rectangular pixels can be left for
> another discussion <g>.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com
> ed at topozone.com
> From: Ian Turton [mailto:ian at geography.leeds.ac.uk]
> Sent: Thursday, January 08, 2004 10:56 AM
> To: Ed McNierney; mapserver-users at lists.gis.umn.edu
> At 09:20 08/01/2004 -0500, Ed McNierney wrote:
> >Ian -
> >How is it possible to honor all parameters when they are not
> consistent?
> You have different scales in the X and Y directions.
> >I certainly understand the need to deal with unusual output
> devices as
> >you describe, but it is not very difficult for the client to address
> >that situation.
> It is difficult for the client to deal with if it asks for
> the image to be distorted but the one it gets back isn't.
> Mapserver should respect the WMS spec on this point (at least
> in wms mode).
> Ian
> Ian Turton, Director, Centre for Computational Geography,
> University of Leeds, Leeds, LS2 9JT
> http://www.geog.leeds.ac.uk/people/i.turton
http://www.ccg.leeds.ac.uk http://www.geotools.org
+44 (0) 113 343 3392 fax: +44 (0) 113 343 3308
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
