[Mapserver-users] WFS and ETRS89
Bart van den Eijnden
bartvde at xs4all.nl
Thu Jan 8 15:15:08 EST 2004
Hi Daniel,
I found it in the EPSG_v64.mdb (Version 6.4, 15-10-2003), but the revision
date in the database for this CRS says 07-12-2002 so it must have been
present since then.
But it is not a problem for Mapserver that is a 3D CRS?
Best regards,
Bart
On Thu, 08 Jan 2004 14:58:29 -0500, Daniel Morissette
<morissette at dmsolutions.ca> wrote:
> Bart van den Eijnden wrote:
>> is it possible to have a Mapserver Web Feature Server operate on a
>> shapefile which is in the ETRS89 coordinate system, and then have it
>> generate GML with the X,Y,Z values?
>> I see there is currently no entry for ETRS89 in the EPSG file delivered
>> with Mapserver (ETRS89 has afaik EPSG code 4346).
>> Is it just a matter of adding the parameters and then it will work?
> You'll have to define EPSG:4346 in your epsg file. I don't think you'll
> be able to get MapServer to use EPSG:4346 without a definition in the
> epsg file.
> I don't know why it's not already there if you say that it's listed by
> EPSG, maybe Frank would know (since he's the PROJ4 maintainer). BTW, it
> might help him to know in which version of the EPSG database you found
> that code.
> Daniel
