[Mapserver-users] Oracle/PHP mapscript issues
chodgson at refractions.net
Thu Jan 8 18:52:32 EST 2004
I am using PHP-mapscript to dynamically set the DATA statement for my
oraclespatial layer as follows:
$lha_layer = $map->getLayerByName( 'Local Health Areas' );
$lha_layer->set( 'status', MS_ON );
$statement = "the_geom FROM (SELECT the_geom, a.lha_id as lha_id, $column FROM
lha_combined_albers a LEFT JOIN lha_stats b ON a.lha_id = b.lha_id)";
$lha_layer->set( 'data', $statement );
When I call $map->draw(), I get the error:
Warning: MapServer Error in msOracleSpatialLayerWhichShapes(): Error parsing
OracleSpatial DATA variable. Must be 'geometry_column FROM table_name [USING
SRID srid#]' or 'geometry_column FROM (SELECT stmt)'.
The select statement inside the () works fine in sqlplus, and the entire data
statement works fine in the mapfile if I use the mapserv cgi to render the map
instead of php-mapscript.
In fact, the whole app worked fine before when I was using postgres/postgis,
I'm just porting it over to oracle spatial.
What am I doing wrong here? Any clues?
Thanks,
Chris Hodgson
