[Mapserver-users] flash output and image folder
James Bjerkholt
james at xenomorphic.com
Fri Jan 16 05:55:54 EST 2004
--Apple-Mail-6--693409456
Content-Transfer-Encoding: quoted-printable
Content-Type: text/plain;
charset=ISO-8859-1;
format=flowed
I am a newbie trying to accomplish the same thing as you:
> finally, i have been trying to set the imagetype to swf.=A0 mapserver=20=
> creates the swf files but without the labels.=A0 i am using truetype=20=
> fonts and fy fontfile looks correct to me.
Have you specified the "OUTPUTFORMAT" object in the .map file to ".swf"=20=
in addition to setting "IMAGETYPE swf"? You may also have to use a=20
different font format than TrueType. See end of this page:=20
http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html
> the swf files get created in the map_web_imagepath folder, but are not=20=
> displayed.
If you are trying to access each single map layer independently as=20
source for an embedded flash on your webpage, and this does not work,=20
then I don't know what is wrong. But if you are simply accessing the=20
"main" generated swf-file in your browser, it will display nothing,=20
because that file only contains information about the other swf-files=20
(.map layers). You will need to make a flash file which dynamically=20
loads each map-layer.swf into an empty movie clip in flash after=20
loading the "main" swf.file (which contains information about the paths=20=
to the other flashfiles among other things)
> i haven't had anyluck setting my map_web_imagepath to anything except=20=
> a hardcoded path like c:inetpub... etc.
> =A0
> is there a trick to using relative paths?
I have also attempted using relative paths - without success. I am also=20=
confused as to what the path should be relative to: the document-root=20
on the webserver? the .mapfile? (seeing as tutorials and other examples=20=
seem to vary) If anyone can share any insight on this it would be much=20=
appreciated.
James
On 9. jan. 2004, at 00.32, jon martin wrote:
> hello,
> =A0
> a couple of newbie questions.
> =A0
Content-Type: text/enriched;
charset=ISO-8859-1
<excerpt><fontfamily><param>Arial</param><smaller>finally, i have been
trying to set the imagetype to swf.=A0 mapserver creates the swf files
but without the labels.=A0 i am using truetype fonts and fy fontfile
looks correct to me.</smaller></fontfamily>
</excerpt>
".swf" in addition to setting "IMAGETYPE swf"? You may also have to
use a different font format than TrueType. See end of this page:
<excerpt><fontfamily><param>Arial</param><smaller>the swf files get
created in the map_web_imagepath folder, but are not =
displayed.</smaller></fontfamily>
</excerpt>
paths to the other flashfiles among other things)
<excerpt><fontfamily><param>Arial</param><smaller>i haven't had
anyluck setting my map_web_imagepath to anything except a hardcoded
path like c:inetpub... etc.</smaller></fontfamily>
=A0
<fontfamily><param>Arial</param><smaller>is there a trick to using
relative paths?</smaller></fontfamily>
</excerpt>
also confused as to what the path should be relative to: the
document-root on the webserver? the .mapfile? (seeing as tutorials and
other examples seem to vary) If anyone can share any insight on this
it would be much appreciated.
James
<excerpt><fontfamily><param>Arial</param><smaller>hello,</smaller></fontfa=
mily>
=A0
<fontfamily><param>Arial</param><smaller>a couple of newbie =
questions.</smaller></fontfamily>
=A0
</excerpt>=
--Apple-Mail-6--693409456--
