[Mapserver-users] happiness
Hugo Nathaniel Rodrigues
hugo at pbh.gov.br
Fri Jan 9 08:07:51 EST 2004
sure, this is the email i sended to one of the forum users about all my
work:
------------------------------ start
i use two php files, one to make my search (the search screen) and other to
send my results to the map (the result screen)...
this are my files:
my map file:
NAME FIRSTMAP
SIZE 400 300
STATUS ON
EXTENT 598047.223047 781652.733880 619791.428883 812944.406142
UNITS METERS
IMAGECOLOR 255 255 255
SYMBOLSET ../etc/symbols.sym
WEB
IMAGEPATH '/tmp/ms_tmp/'
IMAGEURL '/ms_tmp/'
LOG '/tmp/gmap.log'
END
LAYER
NAME prov_bound
CONNECTIONTYPE OGR
CONNECTION 'mapinfo_files/distrito.tab'
METADATA
'DESCRIPTION' 'Province'
END
TYPE POLYGON
STATUS ON
DATA province
CLASS
NAME 'Province'
OUTLINECOLOR 120 120 120
END
END
LAYER
NAME pontomapa
TRANSFORM TRUE
STATUS DEFAULT
TYPE POINT
CLASS
SYMBOL 2
COLOR 0 0 0
SIZE 8
END
# FEATURE
# POINTS 618579.06 806912.68 END
# END
END
END
the php search intro file
// Projeto: Pesquisa de XY em php
// Hugo Nathaniel Rodrigues (hugo at pbh.gov.br / hugonr at terra.com.br)
// Consultor SSSS - Prodabel
// Criação deste modulo: 07/01/2004
// Ultima atualizacao: 07/01/2004
// include("config.php");
error_reporting (E_ERROR | E_PARSE);
if ($btpesquisa != ""){
$conn=mssql_connect($ServidorBanco,$UsuarioBanco,$SenhaBanco);
$lbxendereco = "";
$sql = "SELECT put your fields name here FROM database..table WHERE
STREETNAME LIKE '$rua%' AND TOWNNAME LIKE '$bairro%'";
$resultado = mssql_query($sql);
while($registro = mssql_fetch_array($resultado)){
$lbxendereco = $lbxendereco . "<OPTION VALUE='" . $registro["CODE"] . "'>"
. $registro["TYPE"] . " " . $registro["STREETNAME"] . " - " .
$registro["TOWNTYPE"] . " " . $registro["TOWN"] . "</option>";
mssql_close();
if ($btselecionar != ""){
if (strlen($numimovel) == 1){
$numimovel = "0000" . $numimovel;
if (strlen($numimovel) == 2){
$numimovel = "000" . $numimovel;
if (strlen($numimovel) == 3){
$numimovel = "00" . $numimovel;
if (strlen($numimovel) == 4){
$numimovel = "0" . $numimovel;
$numimovel = $numimovel . strtoupper($letraimovel);
$sql = "SELECT Val_Cood_X, Val_Cood_Y FROM put your xy table here WHERE
NUM_IMOV = '$numimovel' AND STREETCODE = $enderecoselecionado";
$valorx = mssql_result($resultado,0,"Val_Cood_X");
$valory = mssql_result($resultado,0,"Val_Cood_Y");
mssql_close();
<html>
<head>
<title>Pesquisa Endereço XY no mapa</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body bgcolor="#FFFFFF" text="#000000">
<form name="form1" method="post" action="pesquisaphp.php">
<input type="hidden" name="valorx" value="<? echo $valorx; ?>">
<input type="hidden" name="valory" value="<? echo $valory; ?>">
<input type="hidden" name="r" value="<? echo $r; ?>">
<input type="hidden" name="b" value="<? echo $b; ?>">
<input type="hidden" name="num" value="<? echo $numimovel; ?>">
<script language="JavaScript">
if (document.forms[0].valorx.value != ""){
document.forms[0].action =
"http://localhost/pesquisaphp/pesquisaphp.php?pontox=" +
document.forms[0].valorx.value + "&pontoy=" + document.forms[0].valory.value
+ "&rua=" + document.forms[0].r.value + "&bairro=" +
document.forms[0].b.value + "&num=" + document.forms[0].num.value;
document.forms[0].submit();
</script>
<table width="100%" border="1">
<tr>
<td colspan=2> <div align="center"><font color="#FF8000" size="3"
face="Verdana, Arial, Helvetica, sans-serif"><strong>Pesquisa
Endereço</strong></font> </div></td>
</tr>
<? if ($lbxendereco != ""){ ?>
<tr>
<td colspan=2 width="100%" align="left"><b> <font size="3"
Selecione um Endereço e digite o número do seu
imóvel:
</font></b> <br>
<select name="enderecoselecionado" size="2" style="height: 92; width: 638">
<? echo $lbxendereco; ?>
</select>
<br>
<font size="2" face="Verdana, Arial, Helvetica,
sans-serif">Número
do Imóvel:</font>
<input type="text" name="numimovel" value="" size="7">
sans-serif">Letra: </font><input type="text" name="letraimovel" value=""
size="2">
<center>
<INPUT TYPE="SUBMIT" NAME="btselecionar" VALUE="SELECIONAR"
style="background-color: #FFFFFF; color: #000000; font-weight: bold;
font-size: 10 px; border-style: solid; border-color: #808080">
<input type="hidden" name="rua" value="<? echo $rua; ?>">
<input type="hidden" name="bairro" value="<? echo $bairro; ?>">
</center>
</td>
</tr>
<? } else { ?>
<tr>
<td width="25%">
<font size="2" face="Verdana, Arial, Helvetica, sans-serif">Digite o nome
da rua</font>
</td>
<td>
<input type="text" name="rua" value="" size="80">
</td>
</tr>
<tr>
<td width="25%">
do bairro</font>
</td>
<td>
<input type="text" name="bairro" value="" size="80">
</td>
</tr>
<tr>
<td colspan=2 ALIGN="CENTER">
<INPUT TYPE="SUBMIT" NAME="btpesquisa" VALUE="PESQUISAR"
</td>
</tr>
</table>
</form>
</body>
</html>
the php map file:
// $pontox = 610539.39;
// $pontoy = 794816.04;
dl('php_mapscript.dll');
$map_path="/tmp/ms_tmp/";
$map = ms_newMapObj("mapinfo.map");
$l_pontomapa=$map->getLayerByName("pontomapa");
$l_pontomapa->set("status",1);
$pt = ms_newPointObj();
$pt->setXY( $pontox, $pontoy );
$image=$map->draw();
$pt->draw($map, $l_pontomapa, $image, 0, "anyname");
$image_url=$image->saveWebImage(MS_PNG,1,1,0);
<HTML>
<HEAD>
<TITLE>Example 1: Displaying a map</TITLE>
</HEAD>
<BODY>
<font color="#FF8000" size="3" face="Verdana, Arial, Helvetica,
sans-serif"><strong>Endereço:</strong></font>
<br>
<? echo $rua . ", " . $num . " - " . $bairro; ?>
</font>
<br>
<br>
<IMG SRC=<?php echo $image_url; ?> >
</BODY>
</HTML>
------------------------------ end
cheers
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
Sent: Thursday, January 08, 2004 6:05 PM
Subject: Re: [Mapserver-users] happiness
> Congratulations. I'd love to see how you did it if you were willing to
> share :)
> mapserver-users-admin at lists.gis.umn.edu wrote on 01/08/2004 08:58:19 AM:
> > i just finished one little application (my first) where you can type
> > one address with incomplete names of street and town, the
> > application will found all the matches and will give you the list to
> > you to choose one, then you type the number of your address and the
> > application will show you the map of the city with one star symbol
> > in the location of the address you typed... worked very well!!!!!!!!
> > i make it in php accessing ms-sql database and php_mapscript +
> > mapserver (apache / php)
> > thanks for all the support from the forum, special thanks to you
> > daniel, good work guys, good work!!!!!!
> > Hugo Rodrigues
> > Analista/Consultor
> > SSSS - Prodabel
