[Mapserver-users] Shape file and AUTO projection problems
Jay Cable
jcable at gi.alaska.edu
Tue Jan 13 15:15:13 EST 2004
Hello,
I am having problems using shapefiles and the AUTO:42003 projection. When
displaying views of data the encompass the entire earth, mapserver appears
to draw a lot of extra lines to the origin.
Here is a sample image with this problem:
http://oldlady.gina.alaska.edu/~jcable/broken.gif
The problem appears to go away when the area displayed is reduced:
http://oldlady.gina.alaska.edu/~jcable/working.gif
I believe the shapefiles are correct, as they are sample shape files
provided by ERSI. I have also tried other shapefiles and encountered the
same problem.
The problem does not appear to occur with other projections I tried.
Any suggestions as to how I can get around or fix this? Am I doing
something wrong? I tried adjusting the extent with no effect.
I am using mapserver 4.0, but also tried the latest 4.0.1, and it does the
same thing.
Thanks in advance,
-Jay Cable
Here is what my map file looks like:
EXTENT -180.0 -90.0 180.0 90.0
IMAGECOLOR 255 255 255
IMAGETYPE GIF
PROJECTION
"init=epsg:4318"
END
WEB
IMAGEPATH '/home/jcable/SOFTWARE/MAPPING_STUFF/http/htdocs/tmp/'
IMAGEURL '/htdocs/tmp/'
LOG '/home/jcable/SOFTWARE/MAPPING_STUFF/http/htdocs/tmp/log'
METADATA
"wms_srs" "EPSG:4318 AUTO:42003 AUTO:42001 AUTO:42002 AUTO:42004 AUTO:42008"
END
END
# Start of LAYER DEFINITIONS
LAYER # country polygon layer begins here
NAME Country
DATA "/scratch/jcable/shape_files/country"
STATUS DEFAULT
TYPE LINE
PROJECTION
"init=epsg:4318"
END
CLASS
#COLOR 232 0 0
OUTLINECOLOR 232 0 0
END
END # country polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
Jay Cable GINA/ION
tel (907) 474-1856 Geophysical Institute
jcable at gi.alaska.edu University of Alaska
P.O. Box 757320
Fairbanks, AK 99775-7320
