[Mapserver-users] Shape file and AUTO projection problems
Le Ngoc Lam
v0463 at n-koei.co.jp
Tue Jan 13 23:27:25 EST 2004
I guess its projection is wrong.
Try modification below.
Regards,
Lam
EXTENT -180.0 -90.0 180.0 90.0
IMAGECOLOR 255 255 255
IMAGETYPE GIF
PROJECTION
# "init=epsg:4318"
"init=epsg:4326"
END
WEB
IMAGEPATH '/home/jcable/SOFTWARE/MAPPING_STUFF/http/htdocs/tmp/'
IMAGEURL '/htdocs/tmp/'
LOG '/home/jcable/SOFTWARE/MAPPING_STUFF/http/htdocs/tmp/log'
METADATA
"wms_srs" "EPSG:4318 AUTO:42003 AUTO:42001
AUTO:42002 AUTO:42004 AUTO:42008"
END
END
# Start of LAYER DEFINITIONS
LAYER # country polygon layer begins here
NAME Country
DATA "/scratch/jcable/shape_files/country"
STATUS DEFAULT
TYPE LINE
PROJECTION
# "init=epsg:4318"
"init=epsg:4326"
END
CLASS
#COLOR 232 0 0
OUTLINECOLOR 232 0 0
END
END # country polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, January 14, 2004 3:15 AM
Subject: [Mapserver-users] Shape file and AUTO projection problems
> Hello,
> I am having problems using shapefiles and the AUTO:42003 projection. When
> displaying views of data the encompass the entire earth, mapserver appears
> to draw a lot of extra lines to the origin.
> Here is a sample image with this problem:
> http://oldlady.gina.alaska.edu/~jcable/broken.gif
> The problem appears to go away when the area displayed is reduced:
> http://oldlady.gina.alaska.edu/~jcable/working.gif
> I believe the shapefiles are correct, as they are sample shape files
> provided by ERSI. I have also tried other shapefiles and encountered the
> same problem.
> The problem does not appear to occur with other projections I tried.
> Any suggestions as to how I can get around or fix this? Am I doing
> something wrong? I tried adjusting the extent with no effect.
> I am using mapserver 4.0, but also tried the latest 4.0.1, and it does the
> same thing.
> Thanks in advance,
> -Jay Cable
> jcable at gi.alaska.edu
> Here is what my map file looks like:
> IMAGETYPE GIF
> PROJECTION
> "init=epsg:4318"
> END
> WEB
> METADATA
> END
> END
> NAME Country
> STATUS DEFAULT
> TYPE LINE
> PROJECTION
> "init=epsg:4318"
> END
> CLASS
> #COLOR 232 0 0
> END
> Jay Cable GINA/ION
> tel (907) 474-1856 Geophysical Institute
> jcable at gi.alaska.edu University of Alaska
> P.O. Box 757320
> Fairbanks, AK 99775-7320
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
