[Mapserver-users] WFS client tempor ary files
Daniel Morissette
morissette at dmsolutions.ca
Tue Jan 13 22:51:59 EST 2004
Hatcher Matthew wrote:
> The actual error is:
> msHTTPExecuteRequests(): HTTP request error. Can't open output file
> c:\Program Files\Apache
> Group\Apache2\htdocs\tmp\\http___localhost_path_to_wfs_servlet_CONFIG_config
> uration.cfg_SERVICE_WFS_VERSION_1_0_0_TYPENAME_geographic_global_rivers_REQU
> EST_GetFeature_BBOX__73_955808__1_637206_47_955808_79_637206.tmp.gml
> Now, this error only occurs with a long url (i.e. the /localhost/path_to_wfs
> bit which is rather long) - if I shorten this then I don't get the error.
> This seems to be a MapServer thing, rather than a browser thing.
Your analysis was correct that the WFS uses the URL as the base for the
temporary filename of the GML data file. This was only in MS 4.0 and
has changed in MS 4.1, so I would suggest that you try version 4.1 (from
CVS source or nightly build) if you can.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
