[Mapserver-users] MapInfo to Mapserver with additional data
from MySQL
Flavio Hendry
flavio at tydac.ch
Wed Jan 14 05:52:10 EST 2004
Hi Roland
> 1. We need to be able to take the maps from MapInfo and get them into
> a format that can be handled by Mapserver. Is this possible, and if
> so, what is the best way to do it?
You can directly use the MapInfo Format via OGR.
MAP-File Snippet:
LAYER
NAME "waedenswil_poi"
TYPE POINT
MINSCALE 0
MAXSCALE 2000
SYMBOLSCALE 4000
STATUS OFF #OFF
CONNECTIONTYPE OGR
CONNECTION "..\data\poi\waedenswil_poi.TAB"
CLASS
COLOR 255 0 0
TEMPLATE ttt.htm
END # Class section
END
> 2. We need to be able to plot OS Grid Points stored in the MySQL
> database onto the maps when they are produced in MapServer. (Is it
> possible to do this, or does map server only display data from the
> MapInfo export?)
you should be able to create the point from MySQL ...
> Will it be possible to achieve the required solution with the
> technology available?
definitely ...
Kind regards,
Flavio
