[Mapserver-users] RE : OracleSpatial Error
Bart van den Eijnden
bartvde at xs4all.nl
Thu Jan 15 16:05:20 EST 2004
Hi Nicolas,
I had a quick scan through the source code, but think we need to get
debugging working to find out what the problem is, i.e. find out the OCI
error. There are a few OCI calls (among others a connect) which could fail
and have the Mapserver error message you get as a result.
stderr will in Apache go to the Apache error log, I don't know where IIS
will put that, does it have an error log somewhere? You can also use a
file I guess instead of "stderr". But make sure the CGI will get the ENV
VAR "MS_ERRORFILE", in Apache under Windows this has to be done in the
httpd.conf instead of at the operating system level. Again, I don't know
for IIS.
Best regards,
Bart
On Thu, 15 Jan 2004 14:18:30 -0500, <nicolas.fortin at ec.gc.ca> wrote:
> Thx for your fast reply,
> If I make a mistake in the CONNECTION or DATA, I get the same error !
> It's weird I can get an image with shp2img with the same mapfile but not
> with mapserver on the web server.
> The OCI is in the path and IUSR_ have access to it.
> Thx for the info about MS_ERRORFILE but is "stderr" suppose to be a
> file??
> Nicolas
> -----Message d'origine-----
> De : Bart van den Eijnden [mailto:bartvde at xs4all.nl]
> Envoyé : Thursday, January 15, 2004 1:52 PM
> À : nicolas.fortin at ec.gc.ca; mapserver-users at lists.gis.umn.edu
> Objet : Re: RE : [Mapserver-users] RE : OracleSpatial Error
> Hi Nicolas,
> here is some info on the MS_ERRORFILE:
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DebuggingMapserver
> What happens if you make a mistake in the DATA part, e.g. a non-existent
> table? What kind of error message do you get then, normally you would get
> an ORA message, but if it cannot make the connection at all, there must
> be
> something wrong at the connection level. But just to rule out things.
> Is the OCI library in the path?
> Best regards,
> Bart
> On Thu, 15 Jan 2004 13:39:19 -0500, <nicolas.fortin at ec.gc.ca> wrote:
>> Hi Bart!
>> Yes it's the full error message ... No ORA-XXXXX message so it's
>> difficult
>> to know what happens.
>> In the logfile of mapserver (DEBUG TRUE and LOG "log.txt"), the same
>> message
>> is writing by mapserver.
>> I didn't know about the MS_ERRORFILE Env Var...what is it??
>> I'm on Windows 2000 and IIS and both Oracle (Client and DB) are
>> 9.2.0.3 I can't replicate this error nowhere but on this server...and
>> I tried mapserver on 4 workstations/server now.
>> Thx,
>> Nicolas
>> Envoyé : Thursday, January 15, 2004 1:35 PM
>> À : nicolas.fortin at ec.gc.ca; mapserver-users at lists.gis.umn.edu Objet :
>> Re: [Mapserver-users] RE : OracleSpatial Error
>> Hi Nicolas,
>> is this the full error message, or an error message showing up in your
>> browser after performing a WMS request?
>> In other words, have you set the MS_ERRORFILE environment variable to
>> get full debugging output?
>> BTW: what platform is your server on and which Oracle version? Do you
>> have
>> the same (version of the) Oracle client installed on the server and on
>> your workstation? What webserver do you have?
>> Best regards,
>> Bart
>> On Thu, 15 Jan 2004 09:35:53 -0500, <nicolas.fortin at ec.gc.ca> wrote:
>>> Hi again!
>>> My Oracle problem on the server is not solved yet.
>>> msDrawMap(): Image handling error. Failed to draw layer named '1_02'.
>>> msOCIConnect() in msOracleSpatialLayerOpen(): OracleSpatial error.
>>> More observations :
>>> I can get an image with the shp2img utilities and the same mapfile. I
>>> can make Oracle spatial query from SQL*Plus on the server without
>>> error. I use the same layers and Oracle connection/user of this
>>> mapfile on my workstation without error.
>>> The error only appears when the request is made to the web server
>>> I'm open to all kind of suggestions!
>>> Thx
>>> Nicolas
>>> De : nicolas.fortin at ec.gc.ca [mailto:nicolas.fortin at ec.gc.ca] Envoyé
>>> : Tuesday, January 13, 2004 10:29 AM À : nsavard at dmsolutions.ca;
>>> hjulien at nrcan.gc.ca Cc : mapserver-users at lists.gis.umn.edu Objet : RE
>>> : RE : RE : [Mapserver-users] WMS LAYERS= [SOLVED] But an Orac le
>>> one too!
>>> Problem solved!
>>> The mapfile sent below is not exactly the right one, in the other,
>>> one group has the same name as a layer. By renaming the group, all
>>> is back to normal.
>>> Thx for your help!
>>> Now we have a weird oracle error message from the server we're trying
>>> to install mapserver, here it is:
>>> I searched the archive but found nothing...
>>> An idea? Someone...
>>> Nick
>>> : Tuesday, January 13, 2004 9:46 AM À : nsavard at dmsolutions.ca Cc :
>>> mapserver-users at lists.gis.umn.edu Objet : RE : RE : [Mapserver-users]
>>> WMS LAYERS=
>>> Hi Normand, thx for your answer!
>>> No, you don't have access to it cause it's only intranet for the
>>> moment...
>>> This afternoon, I'll try to place the layers like Heryk said to see
>>> if it works.
>>> Here's my wms request:
>>> http://f044d065/mapserv/mapcmitest2.asp?REQUEST=GetMap&SERVICE=wms&VE
>>> R
>>> SION=1
>>> .1.1&Layers=2,1&BBOX=7610000,1222000,7622000,1234000
>>> And my mapfile:
>>> # Mapserver 4.0 for Oracle
>>> # Nicolas Fortin, Env Can nicolas.fortin at ec.gc.ca
>>> # MapFile Test pour la CMI V1.4
>>> NAME IJC4
>>> EXTENT 7610000 1222000 7622000 1234000 #Lac St-Louis
>>> SIZE 425 425
>>> SYMBOLSET 'C:\Inetpub\wwwroot\mapserv\symbols\symbols35.sym'
>>> # Projection LCC de la CMI
>>> PROJECTION
>>> "proj=lcc"
>>> "ellps=GRS80"
>>> "lat_0=63"
>>> "lon_0=-91.8666"
>>> "lat_1=49"
>>> "lat_2=77"
>>> "x_0=6200000"
>>> "y_0=2958000"
>>> "datum=NAD83"
>>> "units=m"
>>> END
>>> WEB
>>> TEMPLATE defaultcmitest1.html
>>> HEADER header.html
>>> FOOTER footer.html
>>> IMAGEPATH "C:/Inetpub/wwwroot/tmp/"
>>> IMAGEURL "/tmp/"
>>> METADATA
>>> wms_title "WMS Quebec Node for IJC test2"
>>> wms_onlineresource "http://f044d065/mapserv/mapcmitest2.asp?"
>>> wms_contactelectronicmailaddress "nicolas.fortin at ec.gc.ca"
>>> wms_contactperson "Nicolas Fortin"
>>> wms_contactorganization "Environnement Canada, SMC-Hydrologie"
>>> wms_contactposition "Programmeur, Analyste de données numériques"
>>> wms_srs "EPSG:4326 EPSG:4269 EPSG:2145 EPSG:42304"
>>> END
>>> END
>>> LEGEND
>>> STATUS ON
>>> LABEL
>>> COLOR 0 0 0
>>> SHADOWCOLOR 218 218 218
>>> SHADOWSIZE 2 2
>>> TYPE BITMAP
>>> SIZE MEDIUM
>>> POSITION CC
>>> PARTIALS FALSE
>>> BUFFER 2
>>> END
>>> END
>>> REFERENCE
>>> STATUS ON
>>> IMAGE "c:\Inetpub\wwwroot\mapserv\images\ref_cmi_lite2.gif"
>>> SIZE 150 150
>>> EXTENT 7549910 1161398 7689518 1363371
>>> COLOR -1 -1 -1
>>> OUTLINECOLOR 255 0 0
>>> END
>>> LAYER
>>> NAME "2"
>>> TYPE POLYGON
>>> CONNECTIONTYPE oraclespatial
>>> CONNECTION "user/****@quebijc"
>>> DATA "POLYGON FROM USR_WATERSHED.VWTRSD_LCC USING SRID 3000000"
>>> STATUS OFF
>>> DUMP TRUE
>>> METADATA
>>> wms_title "Quebec Watersheds"
>>> wms_extent "7035577.31 1082076.03 7833285.05 1507787.39"
>>> END
>>> PROJECTION
>>> "proj=lcc"
>>> "ellps=GRS80"
>>> "lat_0=63"
>>> "lon_0=-91.8666"
>>> "lat_1=49"
>>> "lat_2=77"
>>> "x_0=6200000"
>>> "y_0=2958000"
>>> "datum=NAD83"
>>> "units=m"
>>> END
>>> CLASS
>>> NAME "Watershed"
>>> SYMBOL 'CIRCLE'
>>> SIZE 2
>>> COLOR 255 255 255
>>> OUTLINECOLOR 0 204 0
>>> END
>>> END
>>> LAYER
>>> NAME "1"
>>> TYPE LINE
>>> DATA "LINE FROM USR_SHORELINE.VSHORELINE_LCC USING SRID 3000000"
>>> STATUS DEFAULT
>>> GROUP "Shoreline"
>>> DUMP TRUE
>>> METADATA
>>> wms_title "St. Lawrence River Detailed Shoreline"
>>> wms_extent "7563132.5 1166237.24 7684888.9 1363371.77"
>>> wms_group_title "Shoreline"
>>> END
>>> PROJECTION
>>> "proj=lcc"
>>> "ellps=GRS80"
>>> "lat_0=63"
>>> "lon_0=-91.8666"
>>> "lat_1=49"
>>> "lat_2=77"
>>> "x_0=6200000"
>>> "y_0=2958000"
>>> "datum=NAD83"
>>> "units=m"
>>> END
>>> CLASS
>>> NAME "Detailed Shoreline"
>>> COLOR 0 51 255
>>> SYMBOL 'CIRCLE'
>>> SIZE 1
>>> END
>>> END # Shoreline
>>> END
>>> De : Normand Savard [mailto:nsavard at dmsolutions.ca]
>>> Envoyé : Monday, January 12, 2004 5:05 PM
>>> Cc : hjulien at nrcan.gc.ca; mapserver-users at lists.gis.umn.edu Objet :
>>> Re:
>>> RE :
>>> Hi,
>>> I tried to replicate this problem without success by using our WMS
>>> server used during the OGC compliance tests. I also used the OGC test
>>> suite requests. I joined both the map file and the requests sent
>>> (see below). Theses requests contain three layers. In the first
>>> request, the "Forest" layer is drawn first. In the second request,
>>> the "Forest" layer is drawn last. You can also see that I modified
>>> the
>> mapfile to
>>> set the "Forest" layer status to "DEFAULT". It does not seem to
>>> affect
>>> the drawing order. But maybe I'm missing something. Do we have
>>> access your WMS server? It is possible to have a copy of your
>>> mapfile and the request you are currently sending?
>>> Norm
>>> The requests used are.
>>> http://www2.dmsolutions.ca/cgi-bin/mswms_ogc_cite?VERSION=1.1.1&REQUE
>>> S
>>> T=GetM
>> ap&LAYERS=Forests,Lakes,NamedPlaces&STYLES=&SRS=EPSG:4326&BBOX=-0.0042
>> ,-0.00
>>> 24,0.0042,0.0024&WIDTH=168&HEIGHT=96&FORMAT=image/gif
>>> S
>>> T=GetM
>> ap&LAYERS=NamedPlaces,Lakes,Forests&STYLES=&SRS=EPSG:4326&BBOX=-0.0042
>> ,-0.00
>>> Our map file is as follow:
>>> # Start of map file
>>> # $Id: ogc_cite_wms_server.map,Exp $
>>> NAME OGC_CITE
>>> STATUS ON
>>> SIZE 600 400
>>> ## EPSG:4326 extents
>>> EXTENT -2 -2 -1 6
>>> #EXTENT -0.0042 -0.0024 0.0042 0.0024
>>> UNITS METERS
>>> SHAPEPATH "../data/shapefile"
>>> IMAGECOLOR 255 255 255
>>> FONTSET ../etc/fonts.txt
>>> SYMBOLSET ../etc/symbols.sym
>>> # Start of web interface definition
>>> WEB
>>> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the
>>> root # of the drive where the .MAP file resides. #
>>> IMAGEPATH "/tmp/ms_tmp/"
>>> IMAGEURL "/ms_tmp/"
>>> # LOG "/tmp/gmap.log"
>>> METADATA
>>> "WMS_TITLE" "cite:OGC_CITE WMS Server"
>>> "WMS_ONLINERESOURCE"
>>> "http://www2.dmsolutions.ca/cgi-bin/mswms_ogc_cite?"
>>> "WMS_SRS" "EPSG:4326"
>>> "OWS_SCHEMAS_LOCATION" "http://ogc.dmsolutions.ca"
>>> "WMS_ACCESSCONTRAINTS" "none"
>>> "WMS_FEES" "none"
>>> END
>>> END
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> QUERYMAP
>>> SIZE 200 200
>>> STATUS ON
>>> STYLE HILITE
>>> COLOR 255 0 0
>>> END
>>> # Start of layer definitions
>>> LAYER
>>> NAME BasicPolygons
>>> TYPE POLYGON
>>> STATUS OFF
>>> DATA BasicPolygons
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> TEMPLATE "basicpolygons.html"
>>> CLASS
>>> NAME "BasicPolygons"
>>> COLOR 194 194 194
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:BasicPolygons"
>>> "WMS_ABSTRACT" "BasicPolygons layer."
>>> # "WMS_SRS" "EPSG:4326"
>>> END
>>> END # layer
>>> LAYER
>>> NAME DividedRoutes
>>> TYPE LINE
>>> STATUS ON
>>> DATA DividedRoutes
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> CLASS
>>> NAME "DividedRoutes"
>>> COLOR 0 0 0
>>> OUTLINECOLOR 0 0 0
>>> SYMBOL 'circle'
>>> SIZE 6
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:DividedRoutes"
>>> "WMS_ABSTRACT" "DividedRoutes layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME DividedRoutes_anno
>>> STATUS ON
>>> DATA DividedRoutes
>>> TYPE ANNOTATION
>>> LABELITEM "NAME"
>>> CLASS
>>> NAME "DividedRoutesAnnotations"
>>> COLOR 255 255 255
>>> OUTLINECOLOR 0 0 0
>>> SYMBOL 'routetag'
>>> SIZE 40
>>> OVERLAYSYMBOL "route75"
>>> OVERLAYSIZE 15
>>> OVERLAYCOLOR 0 0 0
>>> LABEL
>>> POSITION CC
>>> COLOR 255 255 255
>>> FONT fritqat
>>> TYPE truetype
>>> SIZE 0
>>> PARTIALS false
>>> END
>>> END
>>> METADATA
>>> "WMS_TITLE" "DividedRoutes"
>>> "WMS_ABSTRACT" "Divided routes layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME MapNeatline
>>> TYPE LINE
>>> STATUS ON
>>> DATA MapNeatline
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> CLASS
>>> NAME "MapNeatline"
>>> COLOR 0 0 0
>>> SYMBOL 'circle'
>>> SIZE 3
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:MapNeatline"
>>> "WMS_ABSTRACT" "MapNeatline layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME NamedPlaces
>>> TYPE POLYGON
>>> STATUS ON
>>> DATA NamedPlaces
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> LABELITEM "NAME"
>>> CLASSITEM "NAME"
>>> TEMPLATE "namedplaces.html"
>>> CLASS
>>> NAME "Ashton"
>>> EXPRESSION "Ashton"
>>> #COLOR 153 153 153
>>> COLOR 192 192 192
>>> OUTLINECOLOR 0 0 0
>>> SIZE 8
>>> LABEL
>>> ANGLE AUTO
>>> COLOR 0 0 0
>>> BACKGROUNDCOLOR 192 192 192
>>> FONT fritqat
>>> TYPE truetype
>>> SIZE 10
>>> POSITION LR
>>> OFFSET 10 10
>>> PARTIALS FALSE
>>> END
>>> END
>>> CLASS
>>> NAME "Goose Island"
>>> EXPRESSION "Goose Island"
>>> COLOR 255 255 255
>>> SIZE 8
>>> TEXT "Goose | Island"
>>> LABEL
>>> ANGLE AUTO
>>> COLOR 0 0 0
>>> BACKGROUNDCOLOR 255 255 255
>>> FONT fritqat
>>> TYPE truetype
>>> SIZE 4
>>> POSITION CC
>>> PARTIALS FALSE
>>> WRAP "|"
>>> END
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:NamedPlaces"
>>> "WMS_ABSTRACT" "NamedPlaces layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME Ponds
>>> TYPE POLYGON
>>> STATUS ON
>>> DATA Ponds
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> TEMPLATE "ponds.html"
>>> CLASS
>>> NAME "Ponds"
>>> COLOR 0 255 255
>>> OUTLINECOLOR 0 0 0
>>> TEXT "Stock Pond"
>>> LABEL
>>> COLOR 0 0 0
>>> FONT fritqat
>>> TYPE truetype
>>> SIZE 9
>>> #POSITION AUTO
>>> POSITION UC
>>> PARTIALS FALSE
>>> OFFSET 0 23
>>> END
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:Ponds"
>>> "WMS_ABSTRACT" "Ponds layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME RoadSegments
>>> TYPE LINE
>>> STATUS ON
>>> DATA RoadSegments
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> LABELITEM "NAME"
>>> CLASSITEM "NAME"
>>> CLASS
>>> NAME "MainStreet"
>>> EXPRESSION "Main Street"
>>> SYMBOL 'circle'
>>> SIZE 3
>>> COLOR 238 0 0
>>> LABEL
>>> ANGLE AUTO
>>> COLOR 0 0 0
>>> FONT fritqat-italic
>>> TYPE truetype
>>> SIZE 10
>>> POSITION UC
>>> PARTIALS FALSE
>>> OFFSET 0 2
>>> END
>>> END
>>> CLASS
>>> NAME "Route5"
>>> EXPRESSION "Route 5"
>>> SYMBOL 'circle'
>>> SIZE 3
>>> COLOR 0 0 0
>>> END
>>> CLASS
>>> NAME "Route75"
>>> EXPRESSION "Dirt Road by Green Forest"
>>> SYMBOL 'circle'
>>> SIZE 5
>>> #COLOR 255 255 0
>>> COLOR 192 160 0
>>> TEXT "Dirt Road"
>>> LABEL
>>> ANGLE 90
>>> COLOR 0 0 0
>>> FONT fritqat-italic
>>> TYPE truetype
>>> SIZE 10
>>> POSITION AUTO
>>> PARTIALS FALSE
>>> #OUTLINECOLOR 255 255 255
>>> OFFSET 0 5
>>> END
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:RoadSegments"
>>> "WMS_ABSTRACT" "RoadSegments layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME RoadSegments_anno
>>> STATUS ON
>>> DATA RoadSegments
>>> TYPE ANNOTATION
>>> CLASSITEM "FID"
>>> LABELITEM "NAME"
>>> CLASS
>>> NAME "Route5NorthEastAnnotations"
>>> EXPRESSION "104"
>>> COLOR 255 255 255
>>> OUTLINECOLOR 0 0 0
>>> #OVERLAYCOLOR 0 0 0
>>> SYMBOL 'routetag'
>>> SIZE 25
>>> OVERLAYSYMBOL "route5"
>>> OVERLAYSIZE 15
>>> OVERLAYCOLOR 0 0 0
>>> LABEL
>>> POSITION CC
>>> COLOR 255 255 255
>>> FONT fritqat
>>> TYPE truetype
>>> SIZE 0
>>> PARTIALS false
>>> END
>>> END
>>> CLASS
>>> NAME "Route5WestAnnotations"
>>> EXPRESSION "102"
>>> COLOR 255 255 255
>>> OUTLINECOLOR 0 0 0
>>> #OVERLAYCOLOR 0 0 0
>>> SYMBOL 'routetag'
>>> SIZE 25
>>> OVERLAYSIZE 15
>>> OVERLAYCOLOR 0 0 0
>>> LABEL
>>> POSITION CC
>>> COLOR 255 255 255
>>> FONT fritqat
>>> TYPE truetype
>>> SIZE 0
>>> PARTIALS false
>>> END
>>> END
>>> METADATA
>>> "WMS_TITLE" "RoadSegments"
>>> END
>>> END #Layer
>>> LAYER
>>> NAME Streams
>>> TYPE LINE
>>> STATUS ON
>>> DATA Streams
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> LABELITEM "NAME"
>>> CLASS
>>> NAME "Streams"
>>> COLOR 0 0 205
>>> OUTLINECOLOR 199 199 199
>>> SYMBOL 'circle'
>>> SIZE 2
>>> LABEL
>>> ANGLE AUTO
>>> COLOR 0 0 205
>>> FONT fritqat-italic
>>> TYPE truetype
>>> SIZE 10
>>> POSITION UC
>>> PARTIALS FALSE
>>> OFFSET 30 5
>>> END
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:Streams"
>>> "WMS_ABSTRACT" "Streams layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME Forests
>>> TYPE POLYGON
>>> # STATUS ON
>>> STATUS DEFAULT
>>> DATA Forests
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> TEMPLATE "forests.html"
>>> CLASS
>>> NAME "Forests"
>>> COLOR 0 150 0
>>> OUTLINECOLOR 0 0 0
>>> MINSIZE 4
>>> #SYMBOL "sapin"
>>> SYMBOL "tree-gif"
>>> SIZE 90
>>> # OVERLAYSYMBOL "square"
>>> # OVERLAYSIZE 50
>>> # OVERLAYCOLOR -1 -1 -1
>>> TEXT "State | Forest"
>>> LABEL
>>> ANGLE AUTO
>>> COLOR 0 0 0
>>> FONT fritqat
>>> TYPE truetype
>>> SIZE 18
>>> POSITION AUTO
>>> PARTIALS FALSE
>>> WRAP "|"
>>> OFFSET 100 -60
>>> END
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:Forests"
>>> "WMS_ABSTRACT" "Forests layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME Bridges
>>> TYPE POINT
>>> STATUS ON
>>> DATA Bridges
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> LABELITEM "NAME"
>>> CLASS
>>> NAME "Bridges"
>>> COLOR 0 0 0
>>> SYMBOL 'bridge'
>>> SIZE 40
>>> LABEL
>>> ANGLE AUTO
>>> COLOR 0 0 0
>>> FONT fritqat-italic
>>> TYPE truetype
>>> SIZE 10
>>> POSITION AUTO
>>> PARTIALS FALSE
>>> OFFSET 20 -8
>>> END
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:Bridges"
>>> "WMS_ABSTRACT" "Bridges layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME Lakes
>>> TYPE POLYGON
>>> STATUS ON
>>> DATA Lakes
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> TEMPLATE "lakes.html"
>>> CLASS
>>> NAME "Lakes"
>>> COLOR 0 0 205
>>> SIZE 8
>>> TEXT "BLUE | LAKE"
>>> LABEL
>>> ANGLE AUTO
>>> COLOR 255 255 255
>>> FONT fritqat
>>> TYPE truetype
>>> SIZE 9
>>> POSITION LL
>>> PARTIALS FALSE
>>> WRAP "|"
>>> OFFSET 15 -10
>>> FORCE true
>>> END
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:Lakes"
>>> "WMS_ABSTRACT" "Lakes layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME Buildings
>>> TYPE POLYGON
>>> STATUS ON
>>> DATA Buildings
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> TEMPLATE "buildings.html"
>>> CLASS
>>> NAME "Buildings"
>>> COLOR 255 255 255
>>> OUTLINECOLOR 0 0 0
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:Buildings"
>>> "WMS_ABSTRACT" "Buildings layer."
>>> END
>>> END # layer
>>> LAYER
>>> NAME BuildingCenters
>>> TYPE POINT
>>> STATUS ON
>>> DATA BuildingCenters
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> CLASS
>>> NAME "BuildingCenters"
>>> COLOR 0 0 0
>>> SYMBOL 'circle'
>>> SIZE 4
>>> END
>>> METADATA
>>> "WMS_TITLE" "cite:BuildingCenters"
>>> "WMS_ABSTRACT" "BuildingCenters layer."
>>> END
>>> END # layer
>>> END # Map File
>>> nicolas.fortin at ec.gc.ca wrote:
>>>> Hi Heryk,
>>>> Only the layer 1 is set to default, all other are set to OFF. I
>>>> thought that doesn't matter in WMS cause you only got the layers you
>>>> are querying.
>>>> I set layer 1 to ON and
>>>> 1- try LAYERS=2,1 and only got layer 2
>>>> 2- try LAYERS=1 and got nothing
>>>> I set layer 1 to OFF (like the others) and
>>>> Weird...
>>>> Nick
>>>> De : Julien, Heryk [mailto:hjulien at nrcan.gc.ca]
>>>> Envoyé : Monday, January 12, 2004 4:00 PM
>>>> À : 'nicolas.fortin at ec.gc.ca'
>>>> Objet : RE: [Mapserver-users] WMS LAYERS=
>>>> Hi,
>>>> Are your layers set to "default" in the mapfile? Is so, you will be
>>>> calling layers 1,2 and all the layers that are set to default! So
>>>> your might be calling layers 1 and 2 a second time around! Try
>>>> setting them to "ON".
>>>> Bonne chance!
>>>> Héryk
>>>> : Monday, January 12, 2004 3:30 PM À :
>>>> Hi list,
>>>> When I make a WMS request with the layers parameters like LAYERS=2,1
>>>> In accordance to the OGC WMS Spec, layer 1 is suppose to be at the
>>>> top of layer 2 but it isn't the case...why??
>>>> Even if I change to LAYERS=1,2 ... no change
>>>> In the mapfile, layer 1 is at the end of the file and is always the
>>>> top layer on others applications using this mapfile.
>>>> Thx for your help,
>>>> Nicolas Fortin
>>>> Mathématicien, Programmeur, Analyste de données
>>>> SMC-Québec Hydrologie, Environnement Canada
>>>> 1141, Rte de l'Église, Sainte-Foy(QC) G1V 4H5
>>>> (418)648-2516
>>>> nicolas.fortin at ec.gc.ca <mailto:nicolas.fortin at ec.gc.ca>
>>>> _______________________________________________
>>>> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
