[Mapserver-users] Longitude and Latitude positions
Todd Birkenholtz
TBirkenholtz at fbfs.com
Fri Jan 16 09:54:27 EST 2004
--0__=1QCQv95f2qLhXvqzLrSyKfu8Toal1HpL62Rg5q6p8OpfMtASzLg0sBSN
Content-type: text/plain; charset=us-ascii
Content-Disposition: inline
I would like to create a map that I can feed it Longitude and Latitude positions
and place a marker at that location.
The positions will be feed from a MySql DB and color of the marker will be
changing depending on different conditions. At some point I would like to be
able to click on the marker to bring up a special webpage describing the
location.
I need some guidance getting started in the right direction.
Thanks your assistance.
Todd Birkenholtz
To:
Content-type: text/plain; charset=iso-8859-1
Content-transfer-encoding: quoted-printable
=A0 =A0 =A0 =A0Todd Birkenholtz/FBFS at FBFS, mapserver-users at lists.gis.um=
n.edu
cc:
Subject: =A0 =A0 =A0 =A0Re: [Mapserver-users] Longitude and Latitude po=
sitions
[IMAGE]
Depending on whether you mean something like the graticule object or a
point label there are a couple of different answers.
As far as the perl example for the graticule object goes - there was a
discussion on the list a little while back regarding that but there is
no final on the results yet.
However, specifying the graticule information in the mapfile directly
seems to work fine.
But then if your thinking of displaying lat-long in the browser as the
mouse moves over the map that requires some form of client-side
scripting, ie. Javascipt.
Lowell
The following message was sent by "Todd Birkenholtz"
<TBirkenholtz at fbfs.com> on Thu, 15 Jan 2004 08:40:37 -0600.
> I am new to Mapserver and the concept of GIS in general. I have a
question that
> I can not seem to be in the docs if it is I guess I do not know the
jargon used
> to describe it.
> How do you mark Longitude and Latitude positions on a map?
[IMAGE]
(Embedded image moved to file: pic24495.pcx)
(See attached file: C.gif)
(See attached file: att1.eml)
Content-type: application/octet-stream;
name="pic24495.pcx"
Content-Disposition: attachment; filename="pic24495.pcx"
Content-transfer-encoding: base64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Content-type: image/gif;
name="C.gif"
Content-Disposition: attachment; filename="C.gif"
Content-Description: Compuserve GIF
R0lGODlhBQAfAIAAAAAAAAAAACwAAAAABQAfAEACIIJ75JWqyYwDD00vCXP1fohBG1CNYJUBnnmh
0JqdW+oNADsA
name="att1.eml"
Content-Disposition: attachment; filename="att1.eml"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--0__=1QCQv95f2qLhXvqzLrSyKfu8Toal1HpL62Rg5q6p8OpfMtASzLg0sBSN--
