[Mapserver-users] Help!
Ronald Kozlowski
ron at umit.maine.edu
Fri Jan 16 13:02:22 EST 2004
So below is what my ./configure output looks like for mapserver 4 (./configure --with-proj --with-gdal --with-WFS). I Make and then Make install which tells me to copy the file over to my cgi-bin.
I do that but when i try to run any of the tutorials I get this for and error? msProcessProjection(): Projection library error. no system list, errno: 2
What is causing this? What did I do wrong. I have PROJ.4 installed , at least it says below it does. So what am I missing? By the way I am using Mandrake 9.2 Thanks !
loading cache ./config.cache
checking for gcc... (cached) gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for c++... (cached) c++
checking whether the C++ compiler (c++ ) works... yes
checking whether the C++ compiler (c++ ) is a cross-compiler... no
checking whether we are using GNU C++... (cached) yes
checking whether c++ accepts -g... (cached) yes
checking for ranlib... (cached) ranlib
checking for flex... (cached) flex
checking for yywrap in -lfl... (cached) yes
checking for bison... (cached) bison -y
checking if compiler supports -R... (cached) no
checking if compiler supports -Wl,-rpath,... (cached) yes
checking for exp in -lm... (cached) yes
checking for __gxx_personality_v0 in -lstdc++... (cached) yes
checking how to run the C preprocessor... (cached) gcc -E
checking for ANSI C header files... (cached) yes
checking for strcasecmp... (cached) yes
checking for strncasecmp... (cached) yes
checking for strdup... (cached) yes
checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
using libjpeg from system libs.
checking where FreeType 2.x is installed...
checking for FT_Init_FreeType in -lfreetype... yes
using libfreetype -lfreetype from system libs.
checking where Zlib is installed...
checking for zlibVersion in -lz... yes
using libz from system libs.
checking where PNG is installed...
checking for png_init_io in -lpng... yes
using libpng from system libs.
checking where libXpm is installed...
checking for XpmFreeXpmImage in -lXpm... no
XPM (libXpm) library cannot be found, possibly needed for GD
checking where libiconv is installed...
checking for libiconv_open in -liconv... yes
using libiconv from system libs.
checking for GD 2.0.12 or higher...
checking for gdImageSetAntiAliased in -lgd... yes
checking for gdImageSetAntiAliased in -lgd... (cached) yes
using libgd 2.0.12 (or higher) from system libs (-L/usr/local/lib -lgd -ljpeg -lfreetype -lpng -lz ).
checking for gdImageCreate in -lgd... yes
checking for gdImageGif in -lgd... no
checking for gdImagePng in -lgd... yes
checking for gdImageJpeg in -lgd... yes
checking for gdImageWBMP in -lgd... yes
checking for gdImageStringFT in -lgd... yes
checking for gdImageGifPtr in -lgd... no
using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT) from system libs.
checking whether we should include PDF support...
checking for PDF_setlinewidth in -lpdf... no
checking for PDF_setrgbcolor in -lpdf... no
checking for PDF_moveto in -lpdf... no
checking for PDF_curveto in -lpdf... no
checking for PDF_show_xy in -lpdf... no
libpdf not found... PDF support not included.
checking whether we should include TIFF support...
checking for TIFFOpen in -ltiff... yes
using libtiff from system libs.
checking whether we should include EPPL7 support...
including EPPL7 support.
checking whether we should include PROJ.4 support...
checking for pj_init in -lproj... yes
checking for pj_transform in -lproj... yes
checking for pj_latlong_from_proj in -lproj... yes
using PROJ.4 from system libs.
checking whether we should include thread safe support...
thread safe support disabled.
checking whether we should include ESRI SDE support...
ESRI SDE support not requested.
checking whether we should compile in MPATROL support...
MPATROL support not requested.
checking whether we should include OGR support...
OGR support not requested.
checking if GDAL support requested... yes
checking for gdal-config... (cached) /usr/local/bin/gdal-config
checking if PostGIS support requested... no
checking if MyGIS support requested... no
checking if OracleSpatial support requested... no
checking if MING/Flash support requested... no
checking whether we should include WMS Server support...
OGC WMS compatibility enabled (-DUSE_WMS_SVR).
checking whether we should include WFS Server support...
OGC WFS Server support not requested.
checking whether we should include WMS Client Connections support...
checking whether we should include WFS Client Connections support...
OGC WFS Client Connections not enabled (PROJ.4, libcurl and OGR required).
checking for curl-config
checking HTTPD server (Apache) version
checking for httpd... (cached) no
'httpd' not found, skipping Apache version detection. You may want to use --with-httpd=/path/to/httpd
Compiling with -DIGNORE_MISSING_DATA.
checking whether we should enable debug features...
checking for PHP/MapScript module options...
PHP/MapScript module not configured.
creating ./config.status
creating Makefile
Ronald N. Kozlowski, MS
Research Associate in New Media, University of Maine
Biological New Media Facility
Tel: 207.581.4532
