[Mapserver-users] Help!
Prashanth Ram
pram at pramcentral.com
Fri Jan 16 19:12:19 EST 2004
What you need to do is copy the files to /usr/lib . Try
copying just one of the files that it said it could not
find to that location and see what happens. It should
say the file was located and give its address. If that
works, then copy all the files to that location.
-Prashanth
On Fri, 16 Jan 2004 19:07:45 -0500, "Ronald Kozlowski"
wrote:
> "Prashanth Ram" <pram at pramcentral.com> writes:
> >Ronald:
> > I presume that you are one *nix system. Try this:
ldd
> >mapserv. It should tell you something like this:
> >libgd.so.2 => /usr/lib/libgd.so.2 (0x4001c000)
> > libfreetype.so.6 => /usr/lib/libfreetype.so.6
> >(0x40055000)
> > libpng.so.3 => /usr/lib/libpng.so.3
> (0x400a7000)
> > libm.so.6 => /lib/libm.so.6 (0x40152000)
> > libstdc++.so.5 => /usr/lib/libstdc++.so.5
> >(0x4046b000)
> > /lib/ld-linux.so.2 => /lib/ld-linux.so.2
> >(0x40000000)
> > libdl.so.2 => /lib/libdl.so.2 (0x40473000)
> >If you get a message like "libxxx.so.2 => not found"
> >then it means that a lib was not found in the path.
> >Just fix the lib. file and everything should be
> working.
> >-Prashanth
> Ok so I did this and none of them say not found. So
now
> what?
> It was also suggested that I don't have espg file in
> the proj director but when I looked it is there.
> stumped:-(
> R
> Ronald N. Kozlowski, MS
> Research Associate in New Media, University of Maine
> Biological New Media Facility
> ron at umit.maine.edu
> Tel: 207.581.4532
