[Mapserver-users] JBox - Getting started - Small problem
Richard Greenwood
rich at greenwoodmap.com
Sun Jan 18 17:06:43 EST 2004
Steve McCrone wrote:
>Hi,
>I'm trying to implement the JBox with the Demo.html sample. I've followed
>the instructions contained in -
>http://mapserver.gis.umn.edu/doc40/jbox-howto.html
>The gif is generated but does not appear, nor does the rubber-band zoom
>rectangle does not appear.
>I beleive it is not finging the JBox.class. It looks dead easy, but!!! -
>here's what I've added-
>function setbox_handler(name, minx, miny, maxx, maxy, redraw) {
>document.mapserv.imgbox.value = minx + " " + miny + " " + maxx + " " + maxy;
>document.mapserv.imgxy.value = minx + " " + miny;
><form method=GET name = "mapserv" action="/cgi-bin/mapserv.exe">
><applet codebase="Java/JBox" code="jBox.class" width=[mapwidth]
>height=[mapheight] name="jBox" MAYSCRIPT>
><param name="image" value="http://[host][img]">
></applet>
><input type="hidden" name="imgbox" value="-1 -1 -1 -1">
>Note: the jbox class etc is in the directory wwwroot/Java/JBox, which is the
>main localhost directory. The demo_init.html and demo.html are also in the
>wwwroot directory.
You might try codebase="/Java/JBox" (preceding slash added). I can not
remember if the codebase is relative to the .map file or the
mapserv.exe, but in either case, setting the path relative to the host
root would be correct given the path to jBox.class that you noted above.
Also look at the source of the page and make sure http://[host][img] has
been correctly processed. It should look something like
http://localhost/tmp/xxxxxxxxxxxx.gif
Rich
Richard Greenwood
www.greenwoodmap.com
