[Mapserver-users] Using CGI to adjust REFERENCE image size
Johansen Per Henrik
phj at norgit.no
Mon Jan 19 03:08:42 EST 2004
> I have been reading the CGI reference and the docs indicate that you can
> change most paramters of the map file from the command line.
> My question can you change the SIZE & IMAGE of the reference map from the command line.
I tried to do the same a few weeks ago, but it did not work for me either at first, but trying to change the map_reference_image and map_reference_extent.
It seem there is a "bug" in the MS lexer, so I had to change a few line in the maplexer.l file, and then recompile MS. This is the diff I used:
diff mapserver-4.0.1/maplexer.l mapserver-4.0.1-perhenrik/maplexer.l
121c121
< <INITIAL>extent { return(EXTENT); }
> <INITIAL,OBJECT_STRING>extent { return(EXTENT); }
138c138
< <INITIAL>image { return(IMAGE); }
> <INITIAL,OBJECT_STRING>image { return(IMAGE); }
After applying this, I was able to chang the variables using map_reference_image and map_reference_extent from cgi. In your case the variables would be map_reference_image and map_reference_size.
Per Henrik
Interconsult NORGIT AS
Per Henrik Johansen
Systemutvikler/Systems developer
Tel: + 47 69 394805 Mob: + 47 950 71822
icq: 4975767
Web: http://www.norgit.no
