[Mapserver-users] connection in mapfile to Oracle spatial is
not used
Flavio Hendry
flavio at tydac.ch
Mon Jan 19 05:03:20 EST 2004
Hi Patricia
I don't know if this helps:
... there will be an additional thing to fix in oracle:
Obviously this is a well know feature (bug). After a successfull
installation of Oracle 8.1.7 you have to change
SQLNET.AUTHENTICATION_SERVICE=(NTS)
to
SQLNET.AUTHENTICATION_SERVICE=()
in sqlnet.ora (search for this file in the dir where you installed
Oracle).
Mit freundlichem Gruss / Best Regards
Flavio Hendry
++++++++++ Neue Neapoljs Seiten auf www.neapoljs.com +++++++++++
############ Mit freundlichen Gruessen / Best Regards
############ Flavio Hendry- mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
To: mapserver-users at lists.gis.umn.edu
Date: Fri, 16 Jan 2004 13:01:53 +0100
Subject: [Mapserver-users] connection in mapfile to Oracle spatial is
not used
> Hi,
> I have successfully run MapServer under IIS 5.0 with some shapefile.
> With a spatial layer i get the error: msDrawMap(): unable to draw
> layer.
> With some onlog-trigger in my database I've shown
> that the connection in the mapfile is not used, there is no logon
> performed.
> I have tried everything I've found in the archive (oci.dll, path,
> ORACLE_HOME).
> Connect through sqlplus is possible.
> Has anyone solved this before?
> Thanks,
> Patricia
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
