[Mapserver-users] Globe View with Orthographic Projection
Harald Wehr
hwehr at hs-harz.de
Wed Jan 21 04:36:24 EST 2004
I want to provide an earth view that looks like a globe. I therefore use
the orthographic projection but get some problems here.
As I dont' know whether it is possible to attach binary files in this
mailing list i put all example files under this url:
http://www2.hs-harz.de/~hwehr/mapserver/
I made 3 examples, every example has a map file, a template output and
the resulting image.
Let me explain the examples. My data resides in a tif-file with world
information in lat/lon format. Example 1 is working as you can see in
the files containing the number 1. This example uses normal lat/lon
projection.
In the 2nd example I switched to orthographic projection with the
extends -4000000 -4000000 4000000 4000000. Projection center is lon=0
and lat=0 and does not change in these examples (I know that this has to
change every time the user performs a click. My client is able to handle
this). This output looks ok to me.
If I enlarge the extend in example 3 the output picture is cut in the
north south direction and I don't know why. I want to be able to enlarge
the extent further so that the user thinks he "moves away" from the
earth but pictures become smaller and smaller in north south direction
when I enlarge the extent further (e.G.-6200000 -6200000 6200000 6200000)
Every extent that is "higher" than the earth radius (6378000) results in
a blank image.
Can you help me here?
Thanks
Harald
