[Mapserver-users] Globe View with Orthographic Projection
Frank Warmerdam
warmerdam at pobox.com
Sat Jan 24 04:58:13 EST 2004
This is a multi-part message in MIME format.
--------------060908050204090102060704
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Harald Wehr wrote:
> I want to provide an earth view that looks like a globe. I therefore use
> the orthographic projection but get some problems here.
> As I dont' know whether it is possible to attach binary files in this
> mailing list i put all example files under this url:
> http://www2.hs-harz.de/~hwehr/mapserver/
> I made 3 examples, every example has a map file, a template output and
> the resulting image.
> Let me explain the examples. My data resides in a tif-file with world
> information in lat/lon format. Example 1 is working as you can see in
> the files containing the number 1. This example uses normal lat/lon
> projection.
> In the 2nd example I switched to orthographic projection with the
> extends -4000000 -4000000 4000000 4000000. Projection center is lon=0
> and lat=0 and does not change in these examples (I know that this has to
> change every time the user performs a click. My client is able to handle
> this). This output looks ok to me.
> If I enlarge the extend in example 3 the output picture is cut in the
> north south direction and I don't know why. I want to be able to enlarge
> the extent further so that the user thinks he "moves away" from the
> earth but pictures become smaller and smaller in north south direction
> when I enlarge the extent further (e.G.-6200000 -6200000 6200000 6200000)
> Every extent that is "higher" than the earth radius (6378000) results in
> a blank image.
Harald,
Sorry for not responding to this message or the form on the osrs-proj list.
There are definately challenges with using MapServer for global level mapping
in projections like orthographic, but with some caveats it can work. I would
like to dig into this but haven't really had time.
I did alot of investigation, and have come to the conclusion that the
PROJ.4 pj_transform() function is not good at returning only a subset of
points successfully transformed. Also, the mapresample.c code, the code used
to reproject *raster* data input to MapServer does not have any reasonable
handling for output map areas that cannot completely be transformed into the
input space.
I have made some corrections to mapresample.c in MapServer and to the
pj_transform() function in PROJ.4 and was able to produce the attached png
with the following .map file:
MAP
NAME "w2qpgi5qsg4k"
DEBUG on
SIZE 400 400
EXTENT -6500000 -6500000 6500000 6500000
LAYER
NAME "world"
TYPE Raster
STATUS default
DATA "/home/warmerda/public_html/world.tif"
PROCESSING "DITHER=YES"
PROJECTION
"proj=latlong"
END
END
PROJECTION
"proj=ortho"
"lat_0=0.0"
"lon_0=0.0"
"x_0=0.0"
"y_0=0.0"
END
END
Success!
Now there are still "issues" with global scale mapping in MapServer, but it
seems we have worked out some significant issues for raster input with
reprojection at least.
The updates are all in CVS, but if you are not comfortable with building
from CVS it may be a while before you can get things working at your end.
Keep in mind that updates are required to the core MapServer as well as
the PROJ.4 libraries.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Content-Type: image/png;
name="out.png"
Content-Transfer-Encoding: base64
Content-Disposition: inline;
filename="out.png"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--------------060908050204090102060704--
