[Mapserver-users] VirtualSpatialData (OGR Connectiontype)
Julien, Heryk
hjulien at nrcan.gc.ca
Wed Jan 21 13:36:31 EST 2004
I'm trying out the Virtual Spatial Data procedure in MapServerWiki
(http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData) with IIS
and an Access 2000 ODBC connection.
I keep on getting the following error message when I attempt ton see my map:
msDrawMap(): Image handling error. Failed to draw layer named 'MGWI_TBLLOC'.
msOGRFileOpen(): OGR error. Open failed for OGR connection `mgwi.ovf'. File
not found or unsupported format.
Anyone can help me?
Here is my virtual file (mgw.ovf):
<OGRVRTDataSource>
<OGRVRTLayer name="MGWI_TBLLOC">
<SrcDataSource>ODBC:MGWI_MAPSERVER</SrcDataSource>
<SrcLayer>tblloc</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<!-- LayerSRS>WGS84</LayerSRS !-->
<GeometryField encoding="PointFromColumns" x="x" y="y"/>
</OGRVRTLayer>
</OGRVRTDataSource>
My virtual layer is in the same directory as my shapefiles:
SHAPEPATH "d:\webcgcq\lcnp\mapserver_demo\maritimes\data\shp\geo83"
Here is the section of my mapfile where I call my virtual layer:
LAYER
NAME "MGWI_TBLLOC"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "mgwi.ovf"
DATA "MGWI_TBLLOC"
STATUS DEFAULT
LABELITEM "LOCID"
PROJECTION
"init=epsg:26920"
END #projection
CLASS
SYMBOL 'circle'
SIZE 8
LABEL
COLOR 132 31 31
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT arial-bold
FORCE true
SIZE 10
POSITION auto
PARTIALS FALSE
MINDISTANCE 0
BUFFER 2
END # end of label
TEMPLATE
"d:\webcgcq\lcnp\mapserver_demo\maritimes\templates\field_capt_query.html"
END # CLASS
END # LAYER
Héryk
NRCan
-----Message d'origine-----
De : Julien, Heryk [mailto:hjulien at nrcan.gc.ca]
Envoyé : Wednesday, January 14, 2004 8:44 AM
À : 'spencer at dmsolutions.ca'
Cc : 'Mapserver-users at lists.gis.umn.edu'
Objet : RE: TR: [Mapserver-users] MySQL and Mapserver
Thanks
Héryk
De : Paul Spencer [mailto:pagameba at magma.ca]
Envoyé : Tuesday, January 13, 2004 5:00 PM
À : Julien, Heryk
Cc : 'Paul Spencer '; 'Mapserver-users at lists.gis.umn.edu'
Objet : Re: TR: [Mapserver-users] MySQL and Mapserver
Maybe you missed it?
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00111.html
Cheers,
Paul
Julien, Heryk wrote:
> Hi Paul,
> Could you send me or post information on the "new format in
> OGR to set up a virtual layer that can draw columns from any ODBC data
> source and map two of the columns to x and y locations"?
> Thanks
> Héryk
> Envoyé : Monday, January 05, 2004 9:23 AM
> Objet : RE: [Mapserver-users] MySQL and Mapserver
> Hi,
> I am also very interseted in that fonction. I would like to be able to map
> well positions from a database x and y colums. Would this permit me to
have
> an up to date point geometry layer which reflects the changes in my well
> database? Can you send me more details?
> Thanks
> Héryk
> NRCan
> Envoyé : Saturday, January 03, 2004 4:28 PM
> À : bartvde at xs4all.nl
> Cc : mapserver-users at lists.gis.umn.edu
> Objet : Re: [Mapserver-users] MySQL and Mapserver
> Bart,
> if you are interested in point geometries only, there is a new format in
> source and map two of the columns to x and y locations. We've used it
> for a couple of clients and it works very nicely. If you are interested
> I can send you more details.
> Cheers,
> Paul
> Bart van den Eijnden wrote:
>>Hi list,
>>I see in the history log that there has been some work done recently
>>(early December) by Attila on supporting MySQL 4.X for the MyGIS
>>connector. Can it be used already?
>>Also, is it possible to keep the geometries in shapefiles and use
>>Mapserver JOINS to link to tables in MySQL?
>>Thanks in advance for the info.
>>Best regards,
>>Bart
>>_______________________________________________
>>Mapserver-users mailing list
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
|Paul Spencer spencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
