[Mapserver-users] Re: VirtualSpatialData (OGR Connectiontype)
Paul Spencer
spencer at dmsolutions.ca
Wed Jan 21 13:43:01 EST 2004
I believe there is a limitation in the OGR OBDC connection that requires
that you provide a user name and password in the OVF file (I think that
is mentioned in the wiki also).
Cheers,
Paul
Julien, Heryk wrote:
> Hi,
> I'm trying out the Virtual Spatial Data procedure in MapServerWiki
> (http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData) with IIS
> and an Access 2000 ODBC connection.
> I keep on getting the following error message when I attempt ton see my map:
> msDrawMap(): Image handling error. Failed to draw layer named 'MGWI_TBLLOC'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection `mgwi.ovf'. File
> not found or unsupported format.
> Anyone can help me?
> Here is my virtual file (mgw.ovf):
> <OGRVRTDataSource>
> <OGRVRTLayer name="MGWI_TBLLOC">
> <SrcDataSource>ODBC:MGWI_MAPSERVER</SrcDataSource>
> <SrcLayer>tblloc</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <!-- LayerSRS>WGS84</LayerSRS !-->
> <GeometryField encoding="PointFromColumns" x="x" y="y"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> My virtual layer is in the same directory as my shapefiles:
> SHAPEPATH "d:\webcgcq\lcnp\mapserver_demo\maritimes\data\shp\geo83"
> Here is the section of my mapfile where I call my virtual layer:
> LAYER
> NAME "MGWI_TBLLOC"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "mgwi.ovf"
> DATA "MGWI_TBLLOC"
> STATUS DEFAULT
> LABELITEM "LOCID"
> PROJECTION
> "init=epsg:26920"
> END #projection
> CLASS
> SYMBOL 'circle'
> SIZE 8
> LABEL
> COLOR 132 31 31
> SHADOWCOLOR 218 218 218
> SHADOWSIZE 2 2
> TYPE TRUETYPE
> FONT arial-bold
> FORCE true
> SIZE 10
> POSITION auto
> PARTIALS FALSE
> MINDISTANCE 0
> BUFFER 2
> END # end of label
> TEMPLATE
> "d:\webcgcq\lcnp\mapserver_demo\maritimes\templates\field_capt_query.html"
> END # CLASS
> END # LAYER
> Héryk
> NRCan
> -----Message d'origine-----
> De : Julien, Heryk [mailto:hjulien at nrcan.gc.ca]
> Envoyé : Wednesday, January 14, 2004 8:44 AM
> À : 'spencer at dmsolutions.ca'
> Cc : 'Mapserver-users at lists.gis.umn.edu'
> Objet : RE: TR: [Mapserver-users] MySQL and Mapserver
> Thanks
> Héryk
> De : Paul Spencer [mailto:pagameba at magma.ca]
> Envoyé : Tuesday, January 13, 2004 5:00 PM
> À : Julien, Heryk
> Cc : 'Paul Spencer '; 'Mapserver-users at lists.gis.umn.edu'
> Objet : Re: TR: [Mapserver-users] MySQL and Mapserver
> Maybe you missed it?
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00111.html
> Cheers,
> Paul
>>Hi Paul,
>>Could you send me or post information on the "new format in
>>OGR to set up a virtual layer that can draw columns from any ODBC data
>>source and map two of the columns to x and y locations"?
>>Thanks
>>Héryk
>>Envoyé : Monday, January 05, 2004 9:23 AM
>>Objet : RE: [Mapserver-users] MySQL and Mapserver
>>Hi,
>>I am also very interseted in that fonction. I would like to be able to map
>>well positions from a database x and y colums. Would this permit me to
> have
>>an up to date point geometry layer which reflects the changes in my well
>>database? Can you send me more details?
>>Thanks
>>Héryk
>>NRCan
>>Envoyé : Saturday, January 03, 2004 4:28 PM
>>À : bartvde at xs4all.nl
>>Cc : mapserver-users at lists.gis.umn.edu
>>Objet : Re: [Mapserver-users] MySQL and Mapserver
>>Bart,
>>if you are interested in point geometries only, there is a new format in
>>source and map two of the columns to x and y locations. We've used it
>>for a couple of clients and it works very nicely. If you are interested
>>I can send you more details.
>>Cheers,
>>Paul
>>Bart van den Eijnden wrote:
>>>Hi list,
>>>I see in the history log that there has been some work done recently
>>>(early December) by Attila on supporting MySQL 4.X for the MyGIS
>>>connector. Can it be used already?
>>>Also, is it possible to keep the geometries in shapefiles and use
>>>Mapserver JOINS to link to tables in MySQL?
>>>Thanks in advance for the info.
>>>Best regards,
>>>Bart
>>>_______________________________________________
>>>Mapserver-users mailing list
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
|Paul Spencer spencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
