[Mapserver-users] Has anyone setup GRASS + Mapserver on Windows
2000 ?
Pericles Nacionales
nacional at cbs.umn.edu
Wed Jan 21 15:12:33 EST 2004
Stephen,
See answers to questions below:
On Wed, 21 Jan 2004, Stephen Clark wrote:
> Perry,
> Do you have a link to compile instructions to libgrass for Windows?
> FYI, I have a VC .NET compiler.
No, sorry, I've never compiled libgrass on Windows--either in Cygwin or
with the native compiler.
> Do you know if GDAL 1.1.9 supports grass directly?
According to the GDAL website, it supports reading of GRASS rasters but
not creating/exporting. See
http://www.remotesensing.org/gdal/frmt_grass.html for more info.
> Also is is possible to script some grass commands and make them available
> via the mapserver interface.
> What I am planning on doing is using GRASS to calculate a shortest route via
> some sort of web interface
> and display the results in Mapserver. Do you know if anyone has tried this?
It sounds like you need to use Mapscript for your project. Others can
probably give you a better answer to this than me. How about it list?
You might also get a better answer to this question from the GRASS mailing
list.
> thanks
> Stephen
Ciao!
-Perry N.
> ----- Original Message -----
> From: "Pericles Nacionales" <nacional at cbs.umn.edu>
> To: "Stephen Clark" <stephen.clark at focus.ca>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, January 20, 2004 2:21 PM
> Subject: Re: [Mapserver-users] Has anyone setup GRASS + Mapserver on Windows
> 2000 ?
> > Stephen,
> > If I haven't completely switched to GNU/Linux I probably would have.
> > Anyway, I can give you an advice if you're planning to go that route. The
> > easiest way to do it is to compile everything under cygwin--GRASS,
> > MapServer, and all the libraries needed (GDAL, PROJ, GD2, etc). You can
> > then use apache or IIS servers but make sure to avoid having spaces on
> > your path names. So, no "C:/Program Files/Apache Group/Apache/htdocs".
> > Instead, install apache directly on "C:\" to get "C:/Apache/htdocs". I
> > don't think you have that problem with IIS since the default
> > directory--"C:\Inetpub\wwwroot"--doesn't contain spaces. There is also a
> > version of apache compiled under cygwin. You can use that instead.
> > Of course, you can just try compiling libgrass natively on Windows. Then
> > you can can try compiling it with GDAL. If it compiles without problems,
> > I'd take my "compiling under cygwin is the easiest way" statement back.
> > The rest is just a matter of finding out how to use GRASS data in
> > MapServer:
> > http://lists.gis.umn.edu/pipermail/mapserver-users/2003-April/003454.html
> > Good luck!
> > -Perry N.
> > On Tue, 20 Jan 2004, Stephen Clark wrote:
> > > Hi all,
> > > I am wondering if there is anyone has setup GRASS + Mapserver on Windows
> 2000 ?
> > > thanks
> > > Stephen
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
