[Mapserver-users] Has anyone setup GRASS + Mapserver on Windows 2000 ?
Stephen Clark
stephen.clark at focus.ca
Wed Jan 21 14:19:34 EST 2004
Perry,
Do you have a link to compile instructions to libgrass for Windows?
FYI, I have a VC .NET compiler.
Do you know if GDAL 1.1.9 supports grass directly?
Also is is possible to script some grass commands and make them available
via the mapserver interface.
What I am planning on doing is using GRASS to calculate a shortest route via
some sort of web interface
and display the results in Mapserver. Do you know if anyone has tried this?
thanks
Stephen
----- Original Message -----
From: "Pericles Nacionales" <nacional at cbs.umn.edu>
To: "Stephen Clark" <stephen.clark at focus.ca>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, January 20, 2004 2:21 PM
Subject: Re: [Mapserver-users] Has anyone setup GRASS + Mapserver on Windows
2000 ?
> Stephen,
> If I haven't completely switched to GNU/Linux I probably would have.
> Anyway, I can give you an advice if you're planning to go that route. The
> easiest way to do it is to compile everything under cygwin--GRASS,
> MapServer, and all the libraries needed (GDAL, PROJ, GD2, etc). You can
> then use apache or IIS servers but make sure to avoid having spaces on
> your path names. So, no "C:/Program Files/Apache Group/Apache/htdocs".
> Instead, install apache directly on "C:\" to get "C:/Apache/htdocs". I
> don't think you have that problem with IIS since the default
> directory--"C:\Inetpub\wwwroot"--doesn't contain spaces. There is also a
> version of apache compiled under cygwin. You can use that instead.
> Of course, you can just try compiling libgrass natively on Windows. Then
> you can can try compiling it with GDAL. If it compiles without problems,
> I'd take my "compiling under cygwin is the easiest way" statement back.
> The rest is just a matter of finding out how to use GRASS data in
> MapServer:
> http://lists.gis.umn.edu/pipermail/mapserver-users/2003-April/003454.html
> Good luck!
> -Perry N.
> On Tue, 20 Jan 2004, Stephen Clark wrote:
> > Hi all,
> > I am wondering if there is anyone has setup GRASS + Mapserver on Windows
2000 ?
> > thanks
> > Stephen
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
