[Mapserver-users] jBox
Wim Blanken PI
wim.blanken at planet.nl
Wed Jan 21 15:17:05 EST 2004
Hello Micheal,
Never saw that one before, seems like a security thingy from father
Microsoft.
I'll have a google search and see what that would bring.....
Anybody any thoughts on this?
Wim Blanken
----- Original Message -----
To: "'Wim Blanken (PI)'" <wim.blanken at planet.nl>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, January 21, 2004 8:57 PM
Subject: RE: [Mapserver-users] jBox
> Just as I got your email I did notice as I moved my cursor over the applet
> window it did give me and error message:
> exception: com.ms.security.SecurityExceptionEx[jBox.init]: Unable to check
> hostname "192.168.110.1http".
> 192.168.110.1 is my IIS webserver ip.
> -----Original Message-----
> From: Wim Blanken (PI) [mailto:wim.blanken at planet.nl]
> Sent: Wednesday, January 21, 2004 1:50 PM
> To: Michael Smith
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] jBox
> Hello Micheal,
> Is the statusbar mentioning that it cannot find the class files? if you
move
> the mousepointer on the applet frame.
> Wim Blanken
> From: "Michael Smith" <msmith at sanangelompo.org>
> To: "'Richard Greenwood'" <rich at greenwoodmap.com>
> Cc: <mapserver-users at lists.gis.umn.edu>; "'Steve Lime'"
> <steve.lime at dnr.state.mn.us>; "'Wim Blanken (PI)'" <wim.blanken at planet.nl>
> Sent: Wednesday, January 21, 2004 8:41 PM
> > I forgot to mention that I am creating gif images.
> > From: Richard Greenwood [mailto:rich at greenwoodmap.com]
> > Sent: Wednesday, January 21, 2004 12:50 PM
> > To: Michael Smith; mapserver-users at lists.gis.umn.edu
> > Michael Smith wrote:
> > > I have jBox installed on windows 2000 IIS 5. I followed (I think)
> > > the instructions on installing. Created wwwroot/java/jBox/ folder
> > > and copied evalThread.class, jBox.java, and jBox.class to that
> directory.
> > You don't need to put jBox.java in there, that's the source code, but
> that's
> > not your problem either.
> > What type of image are you creating: gif, jpeg, png... ?
> > What browser are you using? Have you checked that it works with Java
> > (a
> Java
> > VM is installed and Java is enabled in your browser)? You can test it
> > at http://www2.tetonwyo.org/mapserver
> > Are you getting any error messages?
> > View your page source in your browser and make sure the substitutions
> > are correct in: <param name="image" value="http://[host][img]"> (you
> > should
> not
> > see the square brakets and you should have a valid, accessible path to
> > an image.
> > Rich
> > > modifications to my html file and everthing seems to work other than
> > > I am getting a "gray box" where my map used to be. Does anyone have
> > > any ideas what I may have missed?
> > > Inserted in head of html:
> > > <SCRIPT LANGUAGE="JavaScript">
> > > function setbox_handler(name, minx, miny, maxx, maxy, redraw) {
> > > document.mapserv.imgbox.value = minx + " " + miny + " " +
> > maxx + " "
> > > + maxy;
> > > document.mapserv.imgxy.value = minx + " " + miny; }
> > > function seterror_handler(message) { alert(message); }
> > > </SCRIPT>
> > > Inserted this into the body of the html:
> > > <tr>
> > > <td colspan="2">
> > > <applet codebase="/java/jBox" code="jBox.class"
width="600"
> > > height="600" name="jBox" MAYSCRIPT>
> > > </applet>
> > > </td>
> > > </tr>
> > > AND
> > > <input type="hidden" name="imgbox" value="-1 -1 -1 -1">
> > > Michael Smith, Planner II
> > > City of San Angelo
> > > Planning & Development
> > > 325.657.4210 Fax: 325.481.2648
> > > Email: msmith at sanangelompo.org
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Richard Greenwood
> > www.greenwoodmap.com
