[Mapserver-users] jBox
Michael Smith
msmith at sanangelompo.org
Wed Jan 21 14:57:37 EST 2004
Just as I got your email I did notice as I moved my cursor over the applet
window it did give me and error message:
exception: com.ms.security.SecurityExceptionEx[jBox.init]: Unable to check
hostname "192.168.110.1http".
192.168.110.1 is my IIS webserver ip.
-----Original Message-----
From: Wim Blanken (PI) [mailto:wim.blanken at planet.nl]
Sent: Wednesday, January 21, 2004 1:50 PM
To: Michael Smith
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] jBox
Hello Micheal,
Is the statusbar mentioning that it cannot find the class files? if you move
the mousepointer on the applet frame.
Wim Blanken
----- Original Message -----
To: "'Richard Greenwood'" <rich at greenwoodmap.com>
Cc: <mapserver-users at lists.gis.umn.edu>; "'Steve Lime'"
<steve.lime at dnr.state.mn.us>; "'Wim Blanken (PI)'" <wim.blanken at planet.nl>
Sent: Wednesday, January 21, 2004 8:41 PM
Subject: RE: [Mapserver-users] jBox
> I forgot to mention that I am creating gif images.
> From: Richard Greenwood [mailto:rich at greenwoodmap.com]
> Sent: Wednesday, January 21, 2004 12:50 PM
> To: Michael Smith; mapserver-users at lists.gis.umn.edu
> Michael Smith wrote:
> > I have jBox installed on windows 2000 IIS 5. I followed (I think)
> > the instructions on installing. Created wwwroot/java/jBox/ folder
> > and copied evalThread.class, jBox.java, and jBox.class to that
directory.
> You don't need to put jBox.java in there, that's the source code, but
that's
> not your problem either.
> What type of image are you creating: gif, jpeg, png... ?
> What browser are you using? Have you checked that it works with Java
> (a
Java
> VM is installed and Java is enabled in your browser)? You can test it
> at http://www2.tetonwyo.org/mapserver
> Are you getting any error messages?
> View your page source in your browser and make sure the substitutions
> are correct in: <param name="image" value="http://[host][img]"> (you
> should
not
> see the square brakets and you should have a valid, accessible path to
> an image.
> Rich
> > modifications to my html file and everthing seems to work other than
> > I am getting a "gray box" where my map used to be. Does anyone have
> > any ideas what I may have missed?
> > Inserted in head of html:
> > <SCRIPT LANGUAGE="JavaScript">
> > function setbox_handler(name, minx, miny, maxx, maxy, redraw) {
> > document.mapserv.imgbox.value = minx + " " + miny + " " +
> maxx + " "
> > + maxy;
> > document.mapserv.imgxy.value = minx + " " + miny; }
> > function seterror_handler(message) { alert(message); }
> > </SCRIPT>
> > Inserted this into the body of the html:
> > <tr>
> > <td colspan="2">
> > <applet codebase="/java/jBox" code="jBox.class" width="600"
> > height="600" name="jBox" MAYSCRIPT>
> > </applet>
> > </td>
> > </tr>
> > AND
> > <input type="hidden" name="imgbox" value="-1 -1 -1 -1">
> > Michael Smith, Planner II
> > City of San Angelo
> > Planning & Development
> > 325.657.4210 Fax: 325.481.2648
> > Email: msmith at sanangelompo.org
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Richard Greenwood
> www.greenwoodmap.com
