[Mapserver-users] jBox
Wim Blanken PI
wim.blanken at planet.nl
Wed Jan 21 14:49:45 EST 2004
Hello Micheal,
Is the statusbar mentioning that it cannot find the class files? if you
move the mousepointer on the applet frame.
Wim Blanken
----- Original Message -----
To: "'Richard Greenwood'" <rich at greenwoodmap.com>
Cc: <mapserver-users at lists.gis.umn.edu>; "'Steve Lime'"
<steve.lime at dnr.state.mn.us>; "'Wim Blanken (PI)'" <wim.blanken at planet.nl>
Sent: Wednesday, January 21, 2004 8:41 PM
Subject: RE: [Mapserver-users] jBox
> I forgot to mention that I am creating gif images.
> -----Original Message-----
> From: Richard Greenwood [mailto:rich at greenwoodmap.com]
> Sent: Wednesday, January 21, 2004 12:50 PM
> To: Michael Smith; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] jBox
> Michael Smith wrote:
> > I have jBox installed on windows 2000 IIS 5. I followed (I think) the
> > instructions on installing. Created wwwroot/java/jBox/ folder and
> > copied evalThread.class, jBox.java, and jBox.class to that directory.
> You don't need to put jBox.java in there, that's the source code, but
that's
> not your problem either.
> What type of image are you creating: gif, jpeg, png... ?
> What browser are you using? Have you checked that it works with Java (a
Java
> VM is installed and Java is enabled in your browser)? You can test it at
> http://www2.tetonwyo.org/mapserver
> Are you getting any error messages?
> View your page source in your browser and make sure the substitutions are
> correct in: <param name="image" value="http://[host][img]"> (you should
not
> see the square brakets and you should have a valid, accessible path to an
> image.
> Rich
> > modifications to my html file and everthing seems to work other than I
> > am getting a "gray box" where my map used to be. Does anyone have any
> > ideas what I may have missed?
> > Inserted in head of html:
> > <SCRIPT LANGUAGE="JavaScript">
> > function setbox_handler(name, minx, miny, maxx, maxy, redraw) {
> > document.mapserv.imgbox.value = minx + " " + miny + " " +
> maxx + " "
> > + maxy;
> > document.mapserv.imgxy.value = minx + " " + miny;
> > function seterror_handler(message) {
> > alert(message);
> > </SCRIPT>
> > Inserted this into the body of the html:
> > <tr>
> > <td colspan="2">
> > <applet codebase="/java/jBox" code="jBox.class" width="600"
> > height="600" name="jBox" MAYSCRIPT>
> > </applet>
> > </td>
> > </tr>
> > AND
> > <input type="hidden" name="imgbox" value="-1 -1 -1 -1">
> > Michael Smith, Planner II
> > City of San Angelo
> > Planning & Development
> > 325.657.4210 Fax: 325.481.2648
> > Email: msmith at sanangelompo.org
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Richard Greenwood
> www.greenwoodmap.com
