[Mapserver-users] jBox
Michael Smith
msmith at sanangelompo.org
Wed Jan 21 14:41:19 EST 2004
I forgot to mention that I am creating gif images.
-----Original Message-----
From: Richard Greenwood [mailto:rich at greenwoodmap.com]
Sent: Wednesday, January 21, 2004 12:50 PM
To: Michael Smith; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] jBox
Michael Smith wrote:
> I have jBox installed on windows 2000 IIS 5. I followed (I think) the
> instructions on installing. Created wwwroot/java/jBox/ folder and
> copied evalThread.class, jBox.java, and jBox.class to that directory.
You don't need to put jBox.java in there, that's the source code, but that's
not your problem either.
What type of image are you creating: gif, jpeg, png... ?
What browser are you using? Have you checked that it works with Java (a Java
VM is installed and Java is enabled in your browser)? You can test it at
http://www2.tetonwyo.org/mapserver
Are you getting any error messages?
View your page source in your browser and make sure the substitutions are
correct in: <param name="image" value="http://[host][img]"> (you should not
see the square brakets and you should have a valid, accessible path to an
image.
Rich
> modifications to my html file and everthing seems to work other than I
> am getting a "gray box" where my map used to be. Does anyone have any
> ideas what I may have missed?
> Inserted in head of html:
> <SCRIPT LANGUAGE="JavaScript">
> function setbox_handler(name, minx, miny, maxx, maxy, redraw) {
> document.mapserv.imgbox.value = minx + " " + miny + " " +
maxx + " "
> + maxy;
> document.mapserv.imgxy.value = minx + " " + miny;
> function seterror_handler(message) {
> alert(message);
> </SCRIPT>
> Inserted this into the body of the html:
> <tr>
> <td colspan="2">
> <applet codebase="/java/jBox" code="jBox.class" width="600"
> height="600" name="jBox" MAYSCRIPT>
> </applet>
> </td>
> </tr>
> AND
> <input type="hidden" name="imgbox" value="-1 -1 -1 -1">
> Michael Smith, Planner II
> City of San Angelo
> Planning & Development
> 325.657.4210 Fax: 325.481.2648
> Email: msmith at sanangelompo.org
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Richard Greenwood
www.greenwoodmap.com
