[Mapserver-users] Re: VirtualSpatialData (OGR Connectiontype)
Normand Savard
nsavard at dmsolutions.ca
Thu Jan 22 13:16:50 EST 2004
Julien,
Try
LABELITEM MGWI_TBLLOC #may need to use table.name or just name depending on your OVF file.
in the map file, in the virtual layer section.
Example of a map file:
LAYER
NAME "MyVirtualLayer"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "virtual.ovf" # the name and path to the virtual.ovf file, relative to shapepath may work?
DATA "capitalNames" # the name of the OGRVrtLayer
STATUS ON
LABELITEM capitalName #may need to use table.name or just name depending on your OVF file.
PROJECTION
"init=epsg:4326"
END
CLASS
SYMBOL star
SIZE 10
COLOR 255 0 0
LABEL
SIZE MEDIUM
TYPE BITMAP
COLOR 0 0 0
END
END
END # Layer
Example of an "ovf" file
<OGRVRTDataSource>
<OGRVRTLayer name="capitalNames">
<SrcDataSource>ODBC:NormMyDSN,capital</SrcDataSource>
<SrcLayer>capital</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="XCoord" y="YCoord"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Norm
Julien, Heryk wrote:
>Hi to all,
>I replaced my version of Mapserver with a precompiled one. I also installed
>the latest version of gdal11.dll and ogrinfo from the OpenEV_FW zip.
>As suggested by Frank Warmerdam I used the following SrcDataSource tag in
>the virtual file:
><SrcDataSource>ODBC:MGWI_MAPSERVER</SrcDataSource>. MGWI_MAPSERVER is the
>DSN for my ODBC data source.
>Here is the orginfo output:
>D:\WebScripts\MapServer>ogrinfo --formats
>Loaded OGR Format Drivers:
> -> "ESRI Shapefile" (read/write)
> -> "UK .NTF" (readonly)
> -> "SDTS" (readonly)
> -> "TIGER" (read/write)
> -> "S57" (read/write)
> -> "MapInfo File" (read/write)
> -> "DGN" (read/write)
> -> "VRT" (readonly)
> -> "AVCBin" (readonly)
> -> "REC" (readonly)
> -> "Memory" (read/write)
> -> "GML" (read/write)
> -> "ODBC" (read/write)
> -> "OGDI" (readonly)
> -> "FMEObjects Gateway" (readonly)
>D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf
>ERROR 4: Update access not supported for VRT datasources.
>Had to open data source read-only.
>INFO: Open of
>`D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf'
>using driver `VRT' successful.
>1: MGWI_TBLLOC (Point)
>When I execute Mapserver I got the following message:
>msDrawMap(): Image handling error. Failed to draw layer named 'MGWI_TBLLOC'.
>msOGRFileOpen(): OGR error. Open failed for OGR connection `mgwi.ovf'. File
>not found or unsupported format.
>Thanks for the help
>Héryk
>-----Message d'origine-----
>De : Normand Savard [mailto:nsavard at dmsolutions.ca]
>Envoyé : Wednesday, January 21, 2004 5:26 PM
>À : Julien, Heryk
>Cc : 'spencer at dmsolutions.ca'; 'Mapserver-users at lists.gis.umn.edu';
>Anctil, Martin
>Objet : Re: [Mapserver-users] Re: VirtualSpatialData (OGR
>Connectiontype)
>Julien,
>Just because I do not know all the steps you have done, can you tell me
>if you were able to have some output form "ogrinfo" command?
>Norm
>>Hi Paul,
>>What do I write in the virtual file SrcDataSource tag when I log on a
>Access
>>db with no user restrictions and pass word?
>>I've tried the following combinations without success:
>><SrcDataSource>ODBC:@MGWI_MAPSERVER</SrcDataSource>
>><SrcDataSource>ODBC:/@MGWI_MAPSERVER</SrcDataSource>
>><SrcDataSource>ODBC:administor/@MGWI_MAPSERVER</SrcDataSource>
>><SrcDataSource>ODBC:administeur/@MGWI_MAPSERVER</SrcDataSource>
>>Thanks
>>Héryk
>>De : Paul Spencer [mailto:pagameba at magma.ca]
>>Envoyé : Wednesday, January 21, 2004 1:43 PM
>>À : Julien, Heryk
>>Anctil, Martin
>>Objet : [Mapserver-users] Re: VirtualSpatialData (OGR Connectiontype)
>>I believe there is a limitation in the OGR OBDC connection that requires
>>that you provide a user name and password in the OVF file (I think that
>>is mentioned in the wiki also).
>>Cheers,
>>Paul
>>>Hi,
>>>I'm trying out the Virtual Spatial Data procedure in MapServerWiki
>>>(http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData) with IIS
>>>and an Access 2000 ODBC connection.
>>>I keep on getting the following error message when I attempt ton see my
>>map:
>>'MGWI_TBLLOC'.
>>File
>>>Anyone can help me?
>>>Here is my virtual file (mgw.ovf):
>>><OGRVRTDataSource>
>>> <OGRVRTLayer name="MGWI_TBLLOC">
>>> <SrcLayer>tblloc</SrcLayer>
>>> <!-- LayerSRS>WGS84</LayerSRS !-->
>>> <GeometryField encoding="PointFromColumns" x="x" y="y"/>
>>> </OGRVRTLayer>
>>></OGRVRTDataSource>
>>>My virtual layer is in the same directory as my shapefiles:
>>>SHAPEPATH "d:\webcgcq\lcnp\mapserver_demo\maritimes\data\shp\geo83"
>>>Here is the section of my mapfile where I call my virtual layer:
>>>LAYER
>>> NAME "MGWI_TBLLOC"
>>> TYPE POINT
>>> CONNECTIONTYPE OGR
>>> CONNECTION "mgwi.ovf"
>>> DATA "MGWI_TBLLOC"
>>> STATUS DEFAULT
>>> LABELITEM "LOCID"
>>> PROJECTION
>>> "init=epsg:26920"
>>> END #projection
>>> CLASS
>>> SYMBOL 'circle'
>>> SIZE 8
>>> LABEL
>>> COLOR 132 31 31
>>> SHADOWCOLOR 218 218 218
>>> SHADOWSIZE 2 2
>>> TYPE TRUETYPE
>>> FONT arial-bold
>>> FORCE true
>>> SIZE 10
>>> POSITION auto
>>> PARTIALS FALSE
>>> MINDISTANCE 0
>>> BUFFER 2
>>> END # end of label
>>> TEMPLATE
>>>"d:\webcgcq\lcnp\mapserver_demo\maritimes\templates\field_capt_query.html"
>>> END # CLASS
>>>END # LAYER
>>>Héryk
>>>NRCan
>>>De : Julien, Heryk [mailto:hjulien at nrcan.gc.ca]
>>>Envoyé : Wednesday, January 14, 2004 8:44 AM
>>>À : 'spencer at dmsolutions.ca'
>>>Cc : 'Mapserver-users at lists.gis.umn.edu'
>>>Objet : RE: TR: [Mapserver-users] MySQL and Mapserver
>>>Thanks
>>>Héryk
>>>Envoyé : Tuesday, January 13, 2004 5:00 PM
>>>À : Julien, Heryk
>>>Cc : 'Paul Spencer '; 'Mapserver-users at lists.gis.umn.edu'
>>>Objet : Re: TR: [Mapserver-users] MySQL and Mapserver
>>>Maybe you missed it?
>>http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00111.html
>>>Cheers,
>>>Paul
>>>>Hi Paul,
>>>>Could you send me or post information on the "new format in
>>>>OGR to set up a virtual layer that can draw columns from any ODBC data
>>>>source and map two of the columns to x and y locations"?
>>>>Thanks
>>>>Héryk
>>>>Envoyé : Monday, January 05, 2004 9:23 AM
>>>>Objet : RE: [Mapserver-users] MySQL and Mapserver
>>>>Hi,
>>>>I am also very interseted in that fonction. I would like to be able to
>map
>>>>well positions from a database x and y colums. Would this permit me to
>>>have
>>>>an up to date point geometry layer which reflects the changes in my well
>>>>database? Can you send me more details?
>>>>Thanks
>>>>Héryk
>>>>NRCan
>>>>Envoyé : Saturday, January 03, 2004 4:28 PM
>>>>À : bartvde at xs4all.nl
>>>>Cc : mapserver-users at lists.gis.umn.edu
>>>>Objet : Re: [Mapserver-users] MySQL and Mapserver
>>>>Bart,
>>>>if you are interested in point geometries only, there is a new format in
>>>>source and map two of the columns to x and y locations. We've used it
>>>>for a couple of clients and it works very nicely. If you are interested
>>>>I can send you more details.
>>>>Cheers,
>>>>Paul
>>>>Bart van den Eijnden wrote:
>>>>>Hi list,
>>>>>I see in the history log that there has been some work done recently
>>>>>(early December) by Attila on supporting MySQL 4.X for the MyGIS
>>>>>connector. Can it be used already?
>>>>>Also, is it possible to keep the geometries in shapefiles and use
>>>>>Mapserver JOINS to link to tables in MySQL?
>>>>>Thanks in advance for the info.
>>>>>Best regards,
>>>>>Bart
>>>>>_______________________________________________
>>>>>Mapserver-users mailing list
>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
