[Mapserver-users] Re: VirtualSpatialData (OGR Connectiontype)
Normand Savard
nsavard at dmsolutions.ca
Thu Jan 22 13:47:44 EST 2004
Julien,
What is the exact name of your "ovf" file? Because the name you
specified in the "CONNECTION" parameter in the map file does not match
the one given for you "ovf" file.
See in your email below: "Here is my virtual file (mgw.ovf):"
See your "CONNECTION" parameter into your map file for your specific
virtual layer:
CONNECTIONTYPE OGR
CONNECTION "mgwi.ovf"
Norm
Julien, Heryk wrote:
>Hi to all,
>I replaced my version of Mapserver with a precompiled one. I also installed
>the latest version of gdal11.dll and ogrinfo from the OpenEV_FW zip.
>As suggested by Frank Warmerdam I used the following SrcDataSource tag in
>the virtual file:
><SrcDataSource>ODBC:MGWI_MAPSERVER</SrcDataSource>. MGWI_MAPSERVER is the
>DSN for my ODBC data source.
>Here is the orginfo output:
>D:\WebScripts\MapServer>ogrinfo --formats
>Loaded OGR Format Drivers:
> -> "ESRI Shapefile" (read/write)
> -> "UK .NTF" (readonly)
> -> "SDTS" (readonly)
> -> "TIGER" (read/write)
> -> "S57" (read/write)
> -> "MapInfo File" (read/write)
> -> "DGN" (read/write)
> -> "VRT" (readonly)
> -> "AVCBin" (readonly)
> -> "REC" (readonly)
> -> "Memory" (read/write)
> -> "GML" (read/write)
> -> "ODBC" (read/write)
> -> "OGDI" (readonly)
> -> "FMEObjects Gateway" (readonly)
>D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf
>ERROR 4: Update access not supported for VRT datasources.
>Had to open data source read-only.
>INFO: Open of
>`D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf'
>using driver `VRT' successful.
>1: MGWI_TBLLOC (Point)
>When I execute Mapserver I got the following message:
>msDrawMap(): Image handling error. Failed to draw layer named 'MGWI_TBLLOC'.
>msOGRFileOpen(): OGR error. Open failed for OGR connection `mgwi.ovf'. File
>not found or unsupported format.
>Thanks for the help
>Héryk
>-----Message d'origine-----
>De : Normand Savard [mailto:nsavard at dmsolutions.ca]
>Envoyé : Wednesday, January 21, 2004 5:26 PM
>À : Julien, Heryk
>Cc : 'spencer at dmsolutions.ca'; 'Mapserver-users at lists.gis.umn.edu';
>Anctil, Martin
>Objet : Re: [Mapserver-users] Re: VirtualSpatialData (OGR
>Connectiontype)
>Julien,
>Just because I do not know all the steps you have done, can you tell me
>if you were able to have some output form "ogrinfo" command?
>Norm
>>Hi Paul,
>>What do I write in the virtual file SrcDataSource tag when I log on a
>Access
>>db with no user restrictions and pass word?
>>I've tried the following combinations without success:
>><SrcDataSource>ODBC:@MGWI_MAPSERVER</SrcDataSource>
>><SrcDataSource>ODBC:/@MGWI_MAPSERVER</SrcDataSource>
>><SrcDataSource>ODBC:administor/@MGWI_MAPSERVER</SrcDataSource>
>><SrcDataSource>ODBC:administeur/@MGWI_MAPSERVER</SrcDataSource>
>>Thanks
>>Héryk
>>De : Paul Spencer [mailto:pagameba at magma.ca]
>>Envoyé : Wednesday, January 21, 2004 1:43 PM
>>À : Julien, Heryk
>>Anctil, Martin
>>Objet : [Mapserver-users] Re: VirtualSpatialData (OGR Connectiontype)
>>I believe there is a limitation in the OGR OBDC connection that requires
>>that you provide a user name and password in the OVF file (I think that
>>is mentioned in the wiki also).
>>Cheers,
>>Paul
>>>Hi,
>>>I'm trying out the Virtual Spatial Data procedure in MapServerWiki
>>>(http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData) with IIS
>>>and an Access 2000 ODBC connection.
>>>I keep on getting the following error message when I attempt ton see my
>>map:
>>'MGWI_TBLLOC'.
>>File
>>>Anyone can help me?
>>><OGRVRTDataSource>
>>> <OGRVRTLayer name="MGWI_TBLLOC">
>>> <SrcLayer>tblloc</SrcLayer>
>>> <GeometryType>wkbPoint</GeometryType>
>>> <!-- LayerSRS>WGS84</LayerSRS !-->
>>> <GeometryField encoding="PointFromColumns" x="x" y="y"/>
>>> </OGRVRTLayer>
>>></OGRVRTDataSource>
>>>My virtual layer is in the same directory as my shapefiles:
>>>SHAPEPATH "d:\webcgcq\lcnp\mapserver_demo\maritimes\data\shp\geo83"
>>>Here is the section of my mapfile where I call my virtual layer:
>>>LAYER
>>> NAME "MGWI_TBLLOC"
>>> TYPE POINT
>>> CONNECTIONTYPE OGR
>>> DATA "MGWI_TBLLOC"
>>> STATUS DEFAULT
>>> LABELITEM "LOCID"
>>> PROJECTION
>>> "init=epsg:26920"
>>> END #projection
>>> CLASS
>>> SYMBOL 'circle'
>>> SIZE 8
>>> LABEL
>>> COLOR 132 31 31
>>> SHADOWCOLOR 218 218 218
>>> SHADOWSIZE 2 2
>>> TYPE TRUETYPE
>>> FONT arial-bold
>>> FORCE true
>>> SIZE 10
>>> POSITION auto
>>> PARTIALS FALSE
>>> MINDISTANCE 0
>>> BUFFER 2
>>> END # end of label
>>> TEMPLATE
>>>"d:\webcgcq\lcnp\mapserver_demo\maritimes\templates\field_capt_query.html"
>>> END # CLASS
>>>END # LAYER
>>>Héryk
>>>NRCan
>>>De : Julien, Heryk [mailto:hjulien at nrcan.gc.ca]
>>>Envoyé : Wednesday, January 14, 2004 8:44 AM
>>>À : 'spencer at dmsolutions.ca'
>>>Cc : 'Mapserver-users at lists.gis.umn.edu'
>>>Objet : RE: TR: [Mapserver-users] MySQL and Mapserver
>>>Thanks
>>>Héryk
>>>Envoyé : Tuesday, January 13, 2004 5:00 PM
>>>À : Julien, Heryk
>>>Cc : 'Paul Spencer '; 'Mapserver-users at lists.gis.umn.edu'
>>>Objet : Re: TR: [Mapserver-users] MySQL and Mapserver
>>>Maybe you missed it?
>>http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00111.html
>>>Cheers,
>>>Paul
>>>>Hi Paul,
>>>>Could you send me or post information on the "new format in
>>>>OGR to set up a virtual layer that can draw columns from any ODBC data
>>>>source and map two of the columns to x and y locations"?
>>>>Thanks
>>>>Héryk
>>>>Envoyé : Monday, January 05, 2004 9:23 AM
>>>>Objet : RE: [Mapserver-users] MySQL and Mapserver
>>>>Hi,
>>>>I am also very interseted in that fonction. I would like to be able to
>map
>>>>well positions from a database x and y colums. Would this permit me to
>>>have
>>>>an up to date point geometry layer which reflects the changes in my well
>>>>database? Can you send me more details?
>>>>Thanks
>>>>Héryk
>>>>NRCan
>>>>Envoyé : Saturday, January 03, 2004 4:28 PM
>>>>À : bartvde at xs4all.nl
>>>>Cc : mapserver-users at lists.gis.umn.edu
>>>>Objet : Re: [Mapserver-users] MySQL and Mapserver
>>>>Bart,
>>>>if you are interested in point geometries only, there is a new format in
>>>>source and map two of the columns to x and y locations. We've used it
>>>>for a couple of clients and it works very nicely. If you are interested
>>>>I can send you more details.
>>>>Cheers,
>>>>Paul
>>>>Bart van den Eijnden wrote:
>>>>>Hi list,
>>>>>I see in the history log that there has been some work done recently
>>>>>(early December) by Attila on supporting MySQL 4.X for the MyGIS
>>>>>connector. Can it be used already?
>>>>>Also, is it possible to keep the geometries in shapefiles and use
>>>>>Mapserver JOINS to link to tables in MySQL?
>>>>>Thanks in advance for the info.
>>>>>Best regards,
>>>>>Bart
>>>>>_______________________________________________
>>>>>Mapserver-users mailing list
>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
