[Mapserver-users] Easy mapfile question
Martin, Daniel A
Daniel.A.Martin at erac.com
Thu Jan 22 14:42:44 EST 2004
Whoops,
<quote>Right, MINSCALE and MAXSCALE control a scale range at which a
layer is presented in the layer.</quote> Should read "in the map."
Sorry!
Dan
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Martin, Daniel A
> Sent: Thursday, January 22, 2004 1:15 PM
> To: Jim Buzbee; mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] Easy mapfile question
> I find the easiest way to determine your MINSCALE/MAXSCALE
> settings is to place a [scale] tag in your HTML client.
> I even keep an HTML commented scale that I can see by doing
> "View Source" in all my map clients:
> <!-- scale = 1:[scale] -->
> Then, zoom the client to the scale you would like to set as a
> boundary, and record the value of that [scale] tag. You
> don't even need to understand the units involved (though that
> is set by the UNITS item in your MAP object).
> One of my favorite techniques is have two layers by the same
> name (one presenting more detail than the other) where the
> MAXSCALE for one is the MINSCALE for the other. As the
> client crosses this threshold they are presented with the
> more detailed layer. For instance, showing a highway layer,
> and then switching to a full street map when zoomed close.
> -Dan
> > Jim Buzbee
> > Sent: Thursday, January 22, 2004 12:17 PM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: Re: [Mapserver-users] Easy mapfile question
> > Tyler Mitchell wrote:
> > >>I currently have a single raster image referenced in my map
> > file and
> > >>it is working properly. My question : How do I add
> > additional rasters
> > >>to the map file?
> > > The exact same way, just adding more LAYER....END sections.
> > OK
> > >>For example, say I have a raster map of the western US with
> > extents of
> > >>something like 34N, 114W to 35N, 112W. How do I reference
> > this in my
> > >>map file? Here's my current map file :
> > > I guess your question may be more related to how to make
> the images
> > > line up with each other and/or turn automatically. Are you
> > additional
> > > images georeferenced, i.e. geotiff's or tiffs with world
> > files (.twf)?
> > Right now, that's an open question as I haven't acquired the
> > real data.
> > For a test, I just created a ".wld" file that described a
> > jpeg file and
> > I'm seeing how it fits in. From an earlier response, I gather my
> > MINSCALE and MAXSCALE settings for the layers will tell
> > mapserver when
> > to render the raster?
> > Jim
> > >>MAP
> > >> STATUS ON
> > >> EXTENT -180 -90 180 90
> > >> UNITS DD
> > >> SIZE 640 320
> > >> SHAPEPATH "/usr/apache2/htdocs/maps/"
> > >>WEB
> > >> TEMPLATE world.html
> > >> IMAGEPATH "/usr/apache2/htdocs/tmp/"
> > >> IMAGEURL "/tmp/"
> > >>END
> > >> LAYER
> > >> NAME world
> > >> TYPE RASTER
> > >> DATA world.tif
> > >> STATUS DEFAULT
> > >> END
> > >>END
> > >>Thanks!
> > >>Jim Buzbee
> > >>_______________________________________________
> > >>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > >>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
