[Mapserver-users] How to edit?
Stephen Clark
stephen.clark at focus.ca
Thu Jan 22 16:11:50 EST 2004
This is a multi-part message in MIME format.
------=_NextPart_000_077C_01C3E0E9.4C1F3020
Content-Type: text/plain;
charset="iso-8859-2"
Content-Transfer-Encoding: quoted-printable
Wim,
Will you be putting this up on an internet site?=20
I too am working on something similar that allows a user to draw lines =
in MS interface and save this line as a shape file.
I would be interested in the snippet as well.
thanks
Stephen
----- Original Message -----=20
To: Juraj Cenek=20
Cc: mapserver-users at lists.gis.umn.edu=20
Sent: Thursday, January 22, 2004 11:04 AM
Subject: Re: [Mapserver-users] How to edit?
Hello Juraj,
I have created an application in which you can digitise points, lines =
and polygons with attribute data with Mapserver using CGI mapserver + =
javascript + php and finally a little mapscript to write the shapefile.
It works with a slightly changed jbox that gives the user the ability =
to use the line tool to create points, lines and polygons.
The coordinates are stored in an array and then passed on to the php =
script creating the shapefile.
It works like a charm but i am still testing this but when I am =
finished I could send the snippets to you....
W. Blanken
Geon bv
The Netherlands
To: mapserver-users at lists.gis.umn.edu=20
Sent: Thursday, January 22, 2004 9:07 AM
Subject: [Mapserver-users] How to edit?
Hallo, I have one question about the mapserver, is it possible=20
to modify the maps online (for example every user can create his=20
own layer on the server, when he inputs the password, his layers=20
will appear). Is this possible? (for example user wants to create=20
own map of his trips among his country) I've seen applications,=20
that can input points, but no application, that can include line,=20
polygone......
>Thanx,=20
> Ing. Juraj Cenek
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-2">
<META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Wim,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Will you be putting this up on an =
internet site?=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I too am working on something similar =
that allows a=20
user to draw lines in MS interface and save this line as a shape=20
file.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I would be interested in the snippet as =
well.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thanks</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Stephen</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A title=3Dwim.blanken at planet.nl =
href=3D"mailto:wim.blanken at planet.nl">Wim Blanken=20
(PI)</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A title=3Dcenek at inprop.sk=20
href=3D"mailto:cenek at inprop.sk">Juraj Cenek</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>Cc:</B> <A=20
title=3Dmapserver-users at lists.gis.umn.edu=20
href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.g=
is.umn.edu</A>=20
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Thursday, January 22, =
2004 11:04=20
AM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> Re: [Mapserver-users] =
How to=20
edit?</DIV>
<DIV><BR></DIV>
<DIV><FONT face=3DArial size=3D2>Hello Juraj,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have created an application in =
which you can=20
digitise points, lines and polygons with attribute data with Mapserver =
using=20
CGI mapserver + javascript + php and finally a little mapscript to =
write the=20
shapefile.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>It works with a slightly changed jbox =
that gives=20
the user the ability to use the line tool to create points, lines and=20
polygons.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The coordinates are stored in an =
array and then=20
passed on to the php script creating the shapefile.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>It works like a charm but =
</FONT><FONT face=3DArial=20
size=3D2>i am still testing this but when I am finished I could =
send the=20
snippets to you....</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>W. Blanken</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Geon bv</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The Netherlands</FONT></DIV>
<DIV=20
<A title=3Dcenek at inprop.sk href=3D"mailto:cenek at inprop.sk">Juraj =
Cenek</A>=20
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
is.umn.edu</A>=20
</DIV>
2004 9:07=20
AM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> [Mapserver-users] =
How to=20
edit?</DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
size=3D2></FONT><FONT=20
size=3D2></FONT><BR></DIV>
<DIV><FONT face=3DArial size=3D2><FONT face=3D"Times New Roman" =
size=3D3>Hallo, I=20
have one question about the mapserver, is it possible <BR>to modify =
the maps=20
online (for example every user can create his <BR>own layer on the =
server,=20
when he inputs the password, his layers <BR>will appear). Is this =
possible?=20
(for example user wants to create <BR>own map of his trips among his =
country) I've seen applications, <BR>that can input points, but no=20
application, that can include line, <BR>polygone......<BR>>Thanx, =
<BR>> Ing. Juraj=20
Cenek</FONT><BR></FONT></DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_077C_01C3E0E9.4C1F3020--
