[Mapserver-users] wfs and mapserver4.0.1
    Debbie Pagurek
    pagurekd at agr.gc.ca
    Thu Jan 22 13:31:14 PST 2004
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
--=_4E6F1337.4928024E
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
just as a follow up for the rest of the group, Assefa solved my
difficulty. I had a line in my mapfile that was causing the problem.
Here's what Assefa had to say:
" The problem comes from a setting in the map file (web metadata) :
      "wfs_geometry_element_name" ""
   Here is the decription in the docs related to that :
Name of the element (i.e. attribute) to use for the geometry in GML
output. If not set then "MS_GEOMETRY" will be used. The layer-level
"wfs_geometry_element_name" takes precedence over this value.
In your case you can just remove this metadata from your map file and It
should work. Setting it to an empty string creates a bug in Mapserver.
Note that It is not the case anymore in Mapserver 4.1.
Thanks Assefa!
Debbie
>>> Yewondwossen Assefa <assefa at dmsolutions.ca> 01/22/04 10:44AM >>>
Debbie,
  I can't seem to reproduce this with my test files using 4.0.1. Is it
possible to send me your map file to see if I can reproduce it? If it
happens with all shapefiles, I am assuming data is not the problem and
might be some setting in the map file.
Later,
Debbie Pagurek wrote:
> Hi all,
> is there a bug in wfs in mapserver4.0.1 -
> I keep getting an error for my request:
http://latlong24.gis.agr.gc.ca/cgi-bin/mapserv-4.0.1-new?map=/usr/www/httpd/htdocs/mapdata/debtest/wfscanada.map&version=1.0.0&service=wfs&request=GetFeature&TypeName=canada&Propertyname=NAME
<http://latlong24.gis.agr.gc.ca/cgi-bin/mapserv-4.0.1-new?map=/usr/www/httpd/htdocs/mapdata/debtest/wfscanada.map&version=1.0.0&service=wfs&request=GetFeature&TypeName=canada&Propertyname=NAME>
> The XML page cannot be displayed
> Cannot view XML input using XSL style sheet. Please correct the error
> and then click the Refresh <javascript:location.reload()> button, or
try
> again later.
> A name was started with an invalid character. Error processing
resource
'http://latlong24.gis.agr.gc.ca/cgi-bin/mapserv-4.0.1-new?map=/usr/www/httpd/htdocs/mapdata/debtest/wfscanada.map&version=1.0.0&service=wfs&request=GetFeature&TypeName=canada&Propertyname=NAME'.
> Line 24, Position 10
> and when I do a view source, what i see is that an extra empty tag <>
> that occurs after all of the fields have been listed.  e.g. that part
of
> the gml output:
> <gml:featureMember>
>       <canada>
>         <AREA>585860.072</AREA>
>         <CODE>CA10</CODE>
>         <NAME>Quebec</NAME>
>         <POP1991>6895963</POP1991>
>         <POP91_SQMI>13.163780</POP91_SQMI>
> this happens for whatever shapefile I am using.
> Also, I did try using the latest dev version 4.1 (the windows binary
that
> Assefa made available a little while ago, and this problem goes away.
> Just wondering if I'm creating an incorrect request or if this is a
> known bug.  Also trying to figure out which version of mapserver to
> install on our servers.
> Thanks,
> D. Pagurek
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
Content-Type: text/html; charset=ISO-8859-1
Content-Transfer-Encoding: 8bit
Content-Description: HTML
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 6.00.2800.1276" name=GENERATOR></HEAD>
<BODY style="MARGIN-TOP: 2px; FONT: 10pt Arial; MARGIN-LEFT: 2px">
<DIV>just as a follow up for the rest of the group, Assefa solved my difficulty.
I had a line in my mapfile that was causing the problem.  Here's what
Assefa had to say:</DIV>
<DIV> </DIV>
<DIV>" The problem comes from a setting in the map file (web metadata)
:<BR>      "wfs_geometry_element_name"
""<BR><BR>   Here is the decription in the docs related to that
:<BR>    wfs_geometry_element_name<BR>Name of the element (i.e.
attribute) to use for the geometry in GML <BR>output. If not set then
"MS_GEOMETRY" will be used. The layer-level <BR>"wfs_geometry_element_name"
takes precedence over this value.<BR><BR>In your case you can just remove this
metadata from your map file and It <BR>should work. Setting it to an empty
string creates a bug in Mapserver. <BR>Note that It is not the case anymore in
Mapserver 4.1.<BR>"<BR></DIV>
<DIV>Thanks Assefa!</DIV>
<DIV>Debbie</DIV>
<DIV> </DIV>
<DIV><BR>>>> Yewondwossen Assefa <assefa at dmsolutions.ca> 01/22/04
10:44AM >>><BR>Debbie,<BR><BR>  I can't seem to reproduce this
with my test files using 4.0.1. Is it <BR>possible to send me your map file to
see if I can reproduce it? If it <BR>happens with all shapefiles, I am assuming
data is not the problem and <BR>might be some setting in the map
file.<BR><BR>Later,<BR><BR><BR>Debbie Pagurek wrote:<BR>> Hi all,<BR>> is
there a bug in wfs in mapserver4.0.1 -<BR>> I keep getting an error for my
request:<BR>> <A
href="http://latlong24.gis.agr.gc.ca/cgi-bin/mapserv-4.0.1-new?map=/usr/www/httpd/htdocs/mapdata/debtest/wfscanada.map&version=1.0.0&service=wfs&request=GetFeature&TypeName=canada&Propertyname=NAME">http://latlong24.gis.agr.gc.ca/cgi-bin/mapserv-4.0.1-new?map=/usr/www/httpd/htdocs/mapdata/debtest/wfscanada.map&version=1.0.0&service=wfs&request=GetFeature&TypeName=canada&Propertyname=NAME</A>
<BR>> <<A
href="http://latlong24.gis.agr.gc.ca/cgi-bin/mapserv-4.0.1-new?map=/usr/www/httpd/htdocs/mapdata/debtest/wfscanada.map&version=1.0.0&service=wfs&request=GetFeature&TypeName=canada&Propertyname=NAME">http://latlong24.gis.agr.gc.ca/cgi-bin/mapserv-4.0.1-new?map=/usr/www/httpd/htdocs/mapdata/debtest/wfscanada.map&version=1.0.0&service=wfs&request=GetFeature&TypeName=canada&Propertyname=NAME</A>><BR>>
<BR>> <BR>> The XML page cannot be displayed<BR>> <BR>> Cannot view
XML input using XSL style sheet. Please correct the error <BR>> and then
click the Refresh <javascript:location.reload()> button, or try <BR>>
again later.<BR>> <BR>>
------------------------------------------------------------------------<BR>>
<BR>> A name was started with an invalid character. Error processing resource
<BR>> '<A
href="http://latlong24.gis.agr.gc.ca/cgi-bin/mapserv-4.0.1-new?map=/usr/www/httpd/htdocs/mapdata/debtest/wfscanada.map&version=1.0.0&service=wfs&request=GetFeature&TypeName=canada&Propertyname=NAME'.">http://latlong24.gis.agr.gc.ca/cgi-bin/mapserv-4.0.1-new?map=/usr/www/httpd/htdocs/mapdata/debtest/wfscanada.map&version=1.0.0&service=wfs&request=GetFeature&TypeName=canada&Propertyname=NAME'.</A>
<BR>> Line 24, Position 10<BR>>
<BR>>         <><BR>>
<BR>> and when I do a view source, what i see is that an extra empty tag
<> <BR>> that occurs after all of the fields have been listed.
e.g. that part of <BR>> the gml output:<BR>> <BR>>
<gml:featureMember><BR>>
<canada><BR>>
<AREA>585860.072</AREA><BR>>
<CODE>CA10</CODE><BR>>
<NAME>Quebec</NAME><BR>>
<POP1991>6895963</POP1991><BR>>
<POP91_SQMI>13.163780</POP91_SQMI><BR>>
<><BR>> <BR>> this happens for whatever shapefile I am
using.<BR>> <BR>> Also, I did try using the latest dev version 4.1 (the
windows binary that <BR>> Assefa made available a little while ago, and this
problem goes away.<BR>> <BR>> Just wondering if I'm creating an incorrect
request or if this is a <BR>> known bug.  Also trying to figure out
which version of mapserver to <BR>> install on our servers.<BR>>
<BR>> Thanks,<BR>> D. Pagurek<BR><BR><BR>--
<BR>----------------------------------------------------------------<BR>Assefa
Yewondwossen<BR>Software Analyst<BR><BR>Email: assefa at dmsolutions.ca<BR><A
href="http://www.dmsolutions.ca/">http://www.dmsolutions.ca/</A><BR><BR>Phone:
(613) 565-5056 (ext 14)<BR>Fax:   (613)
565-0925<BR>----------------------------------------------------------------<BR><BR><BR><BR></DIV></BODY></HTML>
--=_4E6F1337.4928024E--
More information about the MapServer-users
