[Mapserver-users] Strange behavior on query mode (CGI)
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Fri Jan 23 07:31:32 EST 2004
http://192.168.0.99/cgi-bin/mapserv?zoom=1&mode=browse&mode=nquery&img.x=224&img.y=173&layer=layLagos&layer=layCober&layer=layRede&layer=layLote&layer=layQuadra&map=%2Fservidor%2Fraiz_apache%2Fferramentas%2Floteamentos%2Floteamento_002.map&imgxy=299.5+199.5&imgext=2257.047013+366.011000+3083.891987+917.756000&program=%2Fcgi-bin%2Fmapserv&app_title=Residencial+Villa+Lombarda&savequery=true
but it works if I use only TEMPLATE, FOOTER and HEADER for the LAYER .
If I put HEADER and FOOTER for the object WEB, it crashes.
Eduardo
Steve Lime escreveu:
> What does the offending call look like? Can you send the URL?
>>>> "Eduardo Patto Kanegae" <eduardo at consultoria.eti.br> 1/22/2004
>>>> 10:41:44 AM >>>
> I'm sorry...
> it's MapServer 4.0.1 for Linux ( on a Suse 9 box) configured with:
> $ ./configure --prefix=/usr/local --host --with-jpeg=/usr/local/bin
> --with-freetype=/usr/include/freetype2 --with-zlib=/usr
> --with-png=/usr --with-gd=/usr --with-xpm=/usr/X11R6/lib
> --with-pdf=/usr/local/mapserver-linux-distro/deps/PDFlib-5.0.2-Linux/bind/c
> --with-tiff=/usr/local --with-eppl --with-proj=/usr/local
> --with-threads --with-ogr --with-gdal --without-ming --with-wfs
> --with-wfsclient --with-wms --with-wmsclient
> --with-curl-config=/usr/local/bin --with-curl=/usr/local/lib
> --enable-ignore-missing-data --disable-debug
> --with-php=/usr/local/mapserver-linux-distro/deps/php-4.3.4
> when run $ mapserv -v , I got:
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF
> INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> ----- the mapfile --------
> MAP
> NAME "loteamento_002" # VARIAVEL
> EXTENT 2382.569 366.011 2958.370 917.756 # VARIAVEL
> FONTSET "/servidor/raiz_apache/ferramentas/loteamentos/fontset.txt"
> SYMBOLSET
> "/servidor/raiz_apache/ferramentas/loteamentos/symbolset.sym"
> IMAGECOLOR 255 255 255 IMAGETYPE PNG # tipo das imagens a
> serem geradas
> INTERLACE ON
> SHAPEPATH
> "/servidor/raiz_apache/ferramentas/loteamentos/loteamento_002"# VARIAVEL
> SIZE 600 400
> STATUS ON
> UNITS METERS
> QUERYMAP
> COLOR 255 255 0 #color of the hilited itens in querymap
> SIZE 300 200 #size of the querymap
> STATUS ON
> STYLE HILITE #style of the selected itens on the query
> END
> WEB
> #EMPTY "/ferramentas/loteamentos/web_empty.html"
> #ERROR "/ferramentas/loteamentos/web_error.html"
> #HEADER
> "/servidor/raiz_apache/ferramentas/loteamentos/web_header.html"
> #FOOTER
> "/servidor/raiz_apache/ferramentas/loteamentos/web_footer.html"
> IMAGEPATH "/servidor/raiz_apache/tmp/"
> IMAGEURL "/tmp/"
> LOG "/servidor/raiz_apache/tmp/loteamento_002.log" # VARIAVEL
> MINSCALE 100 MAXSCALE 10000
> TEMPLATE
> "/servidor/raiz_apache/ferramentas/loteamentos/web_template.html"
> END
> SCALEBAR # inicia a definição do objeto ScaleBar ( Barra de Escala)
> COLOR 0 0 0 # cor da barra de escala
> IMAGECOLOR 255 255 255 #cor de fundo da imagem da barra de
> escala
> INTERVALS 3 #número de segmentos que a barra de escala terá
> LABEL # inicia a definição de objeto Label . AVISO: o objeto
> ScaleBar aceita apenas labels do tipo BITMAP
> COLOR 0 0 0 # cor do texto
> SIZE SMALL # tamanho do texto
> END # finaliza MAP_SCALEBAR_LABEL
> OUTLINECOLOR 0 0 0 # cor de cortorno da barra de escala
> SIZE 300 3 # larguraXaltura da barra de escala
> STATUS ON # define se a imagem temporária da Barra de
> escala deverá ser criada
> STYLE 0 # estilo da barra de escala : 0 = bar style |
> 1 = line style
> UNITS METERS #unidade dos valores da barra de escala
> LEGEND # inicia a definição do objeto LEGEND
> IMAGECOLOR 255 255 255 #cor de fundo da imagem da legenda
> LABEL # inicia a definição de objeto LABEL
> ANTIALIAS TRUE # usar antialias? fica melhor, e
> consequentemente um pouco maior(o tamanho em bytes da imagem) q textos
> sem antialias
> COLOR 0 0 0 #cor do texto
> # FONT "arial" # nome da fonte( previamente definida
> no fontset)
> SIZE SMALL #8 # tamanho do texto
> TYPE BITMAP #TRUETYPE # tipo do texto
> END
> KEYSIZE 15 12 # tamanho dos simbolos da legenda (
> larguraXaltura )
> STATUS ON # define se a imagem temporaria da legenda
> deve ser criada
> END # finaliza MAP_LEGEND
> LAYER
> NAME "layLoteamento"
> TYPE POLYGON
> DATA "loteamento"
> STATUS DEFAULT
> CLASS
> NAME "Divisa loteamento"
> OUTLINECOLOR 128 128 128 COLOR -1 -1 -1
> END
> END
> LAYER
> NAME "layQuadra"
> TYPE POLYGON
> DATA "quadra"
> STATUS OFF
> CLASS
> NAME "Quadras"
> OUTLINECOLOR 32 32 32
> COLOR 255 247 145
> END
> END
> LAYER
> NAME "layLote"
> TYPE POLYGON
> DATA "lotes"
> STATUS OFF
> CLASSITEM "STATUS"
> HEADER
> "/servidor/raiz_apache/ferramentas/loteamentos/lote_header.htm"
> TEMPLATE
> "/servidor/raiz_apache/ferramentas/loteamentos/lote_template.htm"
> FOOTER
> "/servidor/raiz_apache/ferramentas/loteamentos/lote_footer.htm"
> CLASS
> EXPRESSION "V"
> NAME "Vendido"
> OUTLINECOLOR 64 64 64
> COLOR 255 170 170
> END
> CLASS
> EXPRESSION "R"
> NAME "Reservado"
> COLOR 255 168 125
> END
> CLASS
> EXPRESSION "L"
> NAME "Livre"
> COLOR 170 255 170
> END
> END
> LAYER
> NAME "layLote"
> TYPE ANNOTATION
> DATA "lotes"
> STATUS OFF
> CLASSITEM "STATUS"
> LABELMAXSCALE 2000
> SYMBOLSCALE 500
> CLASS
> EXPRESSION "V"
> OUTLINECOLOR -1 -1 -1
> COLOR -1 -1 -1
> TEXT "Vendido"
> LABEL
> ANGLE 60
> ANTIALIAS TRUE
> TYPE TRUETYPE
> SIZE 20
> FONT "arial"
> COLOR 0 0 0 OUTLINECOLOR 255 32 32
> FORCE TRUE
> POSITION CC
> PARTIALS TRUE
> MAXSIZE 32
> MINSIZE 8
> END
> END
> CLASS
> EXPRESSION "R"
> COLOR -1 -1 -1
> TEXT "Reservado"
> LABEL
> BACKGROUNDCOLOR 255 255 0
> BACKGROUNDSHADOWCOLOR 192 192 192
> BACKGROUNDSHADOWSIZE 2 3
> ANGLE -20
> ANTIALIAS TRUE
> TYPE TRUETYPE
> SIZE 12
> FONT "arial"
> COLOR 0 0 0 FORCE TRUE
> POSITION CC
> PARTIALS TRUE
> MAXSIZE 28
> MINSIZE 8
> END
> END
> CLASS
> EXPRESSION "L"
> COLOR -1 -1 -1
> TEXT "Livre"
> LABEL
> ANGLE 0
> ANTIALIAS TRUE
> TYPE TRUETYPE
> SIZE 10
> FONT "arial"
> SHADOWCOLOR 64 128 255
> SHADOWSIZE 1 1
> POSITION CC
> PARTIALS TRUE
> MAXSIZE 24
> MINSIZE 8
> END
> END
> END
> LAYER
> NAME "layRede"
> TYPE LINE
> DATA "rede"
> STATUS OFF
> CLASSITEM "TIPO"
> CLASS
> EXPRESSION "Esgoto"
> NAME "Esgoto" COLOR 137 112 68
> SYMBOL "BOLA"
> SIZE 4
> END
> CLASS
> EXPRESSION "Galeria"
> NAME "Galeria" COLOR 10 255 50
> SYMBOL "BOLA"
> SIZE 3
> END
> CLASS
> EXPRESSION "Agua"
> NAME "Agua" COLOR 0 0 255
> SYMBOL "BOLA"
> SIZE 2
> END
> END
> LAYER
> NAME "layCober"
> TYPE POLYGON
> DATA "cobertura"
> STATUS OFF
> CLASSITEM "TIPO"
> CLASS
> EXPRESSION "Institucional"
> NAME "Institucional"
> COLOR 110 110 110
> END
> CLASS
> EXPRESSION "Área verde"
> NAME "Área verde"
> COLOR 38 115 0
> SYMBOL "ARVORE"
> SIZE 5
> END
> END
> LAYER
> NAME "layLagos"
> TYPE POLYGON
> DATA "lagos"
> STATUS OFF
> CLASS
> NAME "Lagos"
> COLOR 151 219 242
> END
> END
> END
> +Homepage:http://www.consultoria.eti.br ( BRASIL )
> +Perfil:http://www.consultoria.eti.br/ptbr/epk.php
> *Fórum ptMapServer - http://www.consultoria.eti.br/mapserverptforum/ -
> "Discussões relacionadas ao MapServer"
> *ClickBrasil - http://www.consultoria.eti.br/clickbrasil/ - "Mapas do
> Brasil com dados censitários"
> ***Fim da Mensagem / End of Message ***
> On Thu, 22 Jan 2004 10:15:32 -0600, "Steve Lime"
> <steve.lime at dnr.state.mn.us> escreveu:
>> De: "Steve Lime" <steve.lime at dnr.state.mn.us>
>> Data: Thu, 22 Jan 2004 10:15:32 -0600
>> Para: <eduardo at consultoria.eti.br>
>> Assunto: Re: [Mapserver-users] Strange behavior on query mode (CGI)
>> What version? Got a sample mapfile?
>>>>> 9:49:51 AM >>>
>> today I built a very simple Mapserver CGI application and when I
>> select the query mode and click an object, I only got "Internal
>> Server Error" and the apache log only says "Premature end of script
>> headers".
>> so I removed the HEADER and FOOTER parameters of the WEB object in
>> the mapfile, transfered the content
>> of the header file to the layer_header file and the content of the
>> footer file to the layer_footer file,
>> and then tried again.... so, it finally works!
>> what is the problem here?
>> - "Discussões relacionadas ao MapServer"
>> do Brasil com dados censitários"
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
