TR: [Mapserver-users] Re: VirtualSpatialData (OGR Connectiont
ype)
Julien, Heryk
hjulien at nrcan.gc.ca
Fri Jan 23 15:41:12 EST 2004
Hi Norm,
Here is a shortenend version of my mapfile:
NAME Field_cap
EXTENT 38052.652500 4880535.418450 555731.152500 5398894.333450
SHAPEPATH "d:\webcgcq\lcnp\mapserver_demo\maritimes\data\shp\geo83"
UNITS meters
FONTSET "d:\webcgcq\lcnp\mapserver_demo\maritimes\fonts\fontset.dat"
SYMBOLSET
"d:\webcgcq\lcnp\mapserver_demo\maritimes\symbols\symbolset.sym"
SIZE 400 400
IMAGECOLOR 255 255 255
TRANSPARENT ON
PROJECTION
"init=epsg:26920"
END #projection
WEB
TEMPLATE "d:\webcgcq\lcnp\mapserver_demo\maritimes\demo4.html"
IMAGEPATH "d:\webcgcq\temp\"
IMAGEURL "/temp/"
# EMPTY
"http://cgcq.rncan.gc.ca/GASL_clf/mapserver/templates/MS_query_noSel.html"
METADATA
"wms_title" "Field_cap"
"wms_onlineresouce"
"http://www.cgcq.rncan.gc.ca/cgi-bin/mapserver400/mapserv.exe?map=d:\webcgcq
\lcnp\mapserver_demo\maritimes\mapfiles\StatField3.map&"
"wms_srs" "EPSG:4269 EPSG:26920"
"wms_feature_info_mime_type" "Text/html"
END
END
LEGEND
STATUS ON
IMAGECOLOR 200 200 200
LABEL
TYPE TRUETYPE
FONT arial
COLOR 0 0 0
SIZE 10
END
END
SCALEBAR
STATUS ON
IMAGECOLOR 238 238 255
POSITION lc
SIZE 200 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
INTERVALS 5
UNITS KILOMETERS
STYLE 0
LABEL
COLOR 0 0 0
SIZE SMALL
END
END #SCALEBAR
QUERYMAP
SIZE 200 150
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
REFERENCE
COLOR -1 -1 -1
EXTENT -150900 4756000 884457 5596000
STATUS ON
OUTLINECOLOR 255 0 0
SIZE 135 95
"d:\webcgcq\lcnp\mapserver_demo\maritimes\data\raster\refmgwiclr.jpg"
END
LAYER # Centre d'information Topographique - CIT Sherbrooke
NAME "CANIMAGE:CanImage/CanImage"
TYPE RASTER
OFFSITE 0 0 0
STATUS on
CONNECTIONTYPE WMS
CONNECTION "http://wms.cits.rncan.gc.ca/cgi-bin/cubeserv.cgi?"
METADATA
"wms_title" "CANIMAGE"
"wms_name" "CANIMAGE:CanImage/CanImage"
"wms_server_version" "1.1.0"
"wms_srs" "epsg:26920"
"wms_format" "image/jpeg"
END
PROJECTION
"init=epsg:26920"
END
END #
LAYER
NAME "MGWI_TBLLOC"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
"D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf"
DATA "MGWI_TBLLOC"
STATUS default
LABELITEM locid
PROJECTION
"init=epsg:26920"
END #projection
CLASS
SYMBOL 1
SIZE 8
COLOR 255 0 0
LABEL
SIZE MEDIUM
TYPE BITMAP
COLOR 0 0 0
END # end of label
END # CLASS
END # LAYER
END
My ODBC connection: MGWI_MAPSERVER
The name of my Access file is mgwi_transit2000.mdb.
Table name: tblloc
The fields I am interested in are: locid (text 50), loc_ref (text 50),
loc_alias (text 255), X (double), Y (double).
The ovf file:
<OGRVRTDataSource>
<OGRVRTLayer name="MGWI_TBLLOC">
<SrcDataSource>ODBC:MGWI_MAPSERVER,tblloc</SrcDataSource>
<SrcLayer>tblloc</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="X" y="Y"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Thanks again.
Héryk
-----Message d'origine-----
De : Normand Savard [mailto:nsavard at dmsolutions.ca]
Envoyé : Friday, January 23, 2004 2:53 PM
Cc : 'Mapserver-users at lists.gis.umn.edu'
Objet : Re: TR: [Mapserver-users] Re: VirtualSpatialData (OGR
Connectiontype)
Julien,
Is it possible to see the map projection section or if your map file is
not too long could you copy it here? Also, could you joined your
database structure?
Norm
Julien, Heryk wrote:
>Has anyone ever tried connecting to Access 2000?
>That may be the problem.
>Is so I'll have to use a different db software!
>Unfortunatly almost everyone in my office works with Access 2000.
>Thank you all for your patience and help
>Cheers
>Héryk
>De : Arthur, John [mailto:John.Arthur at T-Mobile.com]
>Envoyé : Friday, January 23, 2004 2:09 PM
>À : 'Julien, Heryk'; 'Frank Warmerdam'
>Cc : 'Zak James'; 'Normand Savard'; 'Mapserver-users at lists.gis.umn.edu';
>Anctil, Martin; 'spencer at dmsolutions.ca'
>Objet : RE: [Mapserver-users] Re: VirtualSpatialData (OGR
>Connectiontype)
>I'm using windows with MSSQL for this one. In your CONNECTION tag, try
>using "/" instead of "\":
>"D:/webCGCq/lcnp/mapserver_demo/maritimes/data/shp/geo83/mgwi.ovf"
>-----Original Message-----
>From: Julien, Heryk [mailto:hjulien at nrcan.gc.ca]
>Sent: Friday, January 23, 2004 2:03 PM
>To: 'Frank Warmerdam'; Arthur, John
>Cc: 'Zak James'; 'Normand Savard'; 'Mapserver-users at lists.gis.umn.edu';
>Subject: RE: [Mapserver-users] Re: VirtualSpatialData (OGR
>Connectiontype)
>Okay,
>If run the orginfo with the ODBC connection name (MGWI_TBLLOC) instead of
>the Access table name (tblloc) I get my table content. Thanks.
>Now I'm back to the original problem. All the components seem to work
>perfectly but I keep on getting the same error message when I try to draw
>the map:
>msDrawMap(): Image handling error. Failed to draw layer named
'MGWI_TBLLOC'.
>msOGRFileOpen(): OGR error. Open failed for OGR connection
>`D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf'. File
not
>found or unsupported format.
>It doesn't seem to find the mgwi.ovf file. I tried both relative and
>absolute paths. I checked my mapfile and everyting seems okay
>LAYER
> NAME "MGWI_TBLLOC"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION
> DATA "MGWI_TBLLOC"
> STATUS default
> LABELITEM locid
> PROJECTION
> "init=epsg:26920"
> END #projection
> CLASS
> SYMBOL 1
> SIZE 8
> COLOR 255 0 0
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> COLOR 0 0 0
> END # end of label
> END # CLASS
>END # LAYER
>John, are you using an Access database? Are you working on Linux or Window?
>Thank you all for your help
>Héryk
>mgwi.ovf:
><OGRVRTDataSource>
> </OGRVRTLayer>
></OGRVRTDataSource>
>De : Frank Warmerdam [mailto:warmerdam at pobox.com]
>Envoyé : Friday, January 23, 2004 10:24 AM
>À : Julien, Heryk
>Cc : 'Zak James'; 'Arthur, John'; 'Normand Savard';
>'Mapserver-users at lists.gis.umn.edu'; Anctil, Martin;
>Objet : Re: [Mapserver-users] Re: VirtualSpatialData (OGR
>Connectiontype)
>>Hi,
>>I tried it and I don't get the table content!
>>Firt try:
>>D:\WebScripts\MapServer>ogrinfo
>>ERROR 4: Update access not supported for VRT datasources.
>>Had to open data source read-only.
>>INFO: Open of
>>using driver `VRT' successful.
>>1: MGWI_TBLLOC (Point)
>>Second try with the table name:
>>D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf tblloc
>>INFO: Open of
>>The table doesn't seem to be coming through! Any idea?
>>I tried the new build that Paul made available this morning and I get the
>>same problem!
>Hi,
>I'm not sure if I missed some of the email on this thread (it is pretty
>overwhelming!) but you didn't use the correct table name in your ogrinfo
>query. When you ran ogrinfo without the layer name you got "1: MGWI_TBLLOC
>(Point)" as the result. The "MGWI_TBLLOC" portion of this is the layer
>name. So you should use it, not TBLLOC as the layer name in your ogrinfo
>query:
>Good luck,
Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
