TR: [Mapserver-users] Re: VirtualSpatialData (OGR Connectiontype)
Paul Spencer
spencer at dmsolutions.ca
Fri Jan 23 18:15:18 EST 2004
Heryk
Is it possible that you have created a User DSN instead of a System DSN?
Just grasping right now.
Paul
Julien, Heryk wrote:
> Has anyone ever tried connecting to Access 2000?
> That may be the problem.
> Is so I'll have to use a different db software!
> Unfortunatly almost everyone in my office works with Access 2000.
> Thank you all for your patience and help
> Cheers
> Héryk
> -----Message d'origine-----
> De : Arthur, John [mailto:John.Arthur at T-Mobile.com]
> Envoyé : Friday, January 23, 2004 2:09 PM
> À : 'Julien, Heryk'; 'Frank Warmerdam'
> Cc : 'Zak James'; 'Normand Savard'; 'Mapserver-users at lists.gis.umn.edu';
> Anctil, Martin; 'spencer at dmsolutions.ca'
> Objet : RE: [Mapserver-users] Re: VirtualSpatialData (OGR
> Connectiontype)
> I'm using windows with MSSQL for this one. In your CONNECTION tag, try
> using "/" instead of "\":
> "D:/webCGCq/lcnp/mapserver_demo/maritimes/data/shp/geo83/mgwi.ovf"
> -----Original Message-----
> From: Julien, Heryk [mailto:hjulien at nrcan.gc.ca]
> Sent: Friday, January 23, 2004 2:03 PM
> To: 'Frank Warmerdam'; Arthur, John
> Cc: 'Zak James'; 'Normand Savard'; 'Mapserver-users at lists.gis.umn.edu';
> Subject: RE: [Mapserver-users] Re: VirtualSpatialData (OGR
> Connectiontype)
> Okay,
> If run the orginfo with the ODBC connection name (MGWI_TBLLOC) instead of
> the Access table name (tblloc) I get my table content. Thanks.
> Now I'm back to the original problem. All the components seem to work
> perfectly but I keep on getting the same error message when I try to draw
> the map:
> msDrawMap(): Image handling error. Failed to draw layer named 'MGWI_TBLLOC'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection
> `D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf'. File not
> found or unsupported format.
> It doesn't seem to find the mgwi.ovf file. I tried both relative and
> absolute paths. I checked my mapfile and everyting seems okay
> LAYER
> NAME "MGWI_TBLLOC"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION
> "D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf"
> DATA "MGWI_TBLLOC"
> STATUS default
> LABELITEM locid
> PROJECTION
> "init=epsg:26920"
> END #projection
> CLASS
> SYMBOL 1
> SIZE 8
> COLOR 255 0 0
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> COLOR 0 0 0
> END # end of label
> END # CLASS
> END # LAYER
> John, are you using an Access database? Are you working on Linux or Window?
> Thank you all for your help
> Héryk
> mgwi.ovf:
> <OGRVRTDataSource>
> <OGRVRTLayer name="MGWI_TBLLOC">
> <SrcDataSource>ODBC:MGWI_MAPSERVER,tblloc</SrcDataSource>
> <SrcLayer>tblloc</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="X" y="Y"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> De : Frank Warmerdam [mailto:warmerdam at pobox.com]
> Envoyé : Friday, January 23, 2004 10:24 AM
> À : Julien, Heryk
> Cc : 'Zak James'; 'Arthur, John'; 'Normand Savard';
> 'Mapserver-users at lists.gis.umn.edu'; Anctil, Martin;
> Objet : Re: [Mapserver-users] Re: VirtualSpatialData (OGR
> Connectiontype)
>>Hi,
>>I tried it and I don't get the table content!
>>Firt try:
>>D:\WebScripts\MapServer>ogrinfo
>>ERROR 4: Update access not supported for VRT datasources.
>>Had to open data source read-only.
>>INFO: Open of
>>using driver `VRT' successful.
>>1: MGWI_TBLLOC (Point)
>>Second try with the table name:
>>D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf tblloc
>>INFO: Open of
>>The table doesn't seem to be coming through! Any idea?
>>I tried the new build that Paul made available this morning and I get the
>>same problem!
> Hi,
> I'm not sure if I missed some of the email on this thread (it is pretty
> overwhelming!) but you didn't use the correct table name in your ogrinfo
> query. When you ran ogrinfo without the layer name you got "1: MGWI_TBLLOC
> (Point)" as the result. The "MGWI_TBLLOC" portion of this is the layer
> name. So you should use it, not TBLLOC as the layer name in your ogrinfo
> query:
> Good luck,
|Paul Spencer spencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
