[Mapserver-users] compiling against .so or sources? what is better?
Daniel Morissette
morissette at dmsolutions.ca
Fri Jan 23 17:18:35 EST 2004
Eduardo Patto Kanegae wrote:
> What is the diference between compile a feature with its source or with
> its shared object lib ?
> eg:
> ./configure --with-foo=/usr/local/lib # poiting to libfoo.so
> or
> ./configure --with-foo=/usr/local/foo/src # pointing to foo.h and other
> "foo" C sources...
> thanks
You should use the installed version of the library whenever possible
(unless you really know what you're doing). Pointing directly to the
source tree usually leads to trouble at runtime.
Note that when pointing to the installed version, in general you
shouldn't include the "lib" directory in the path, i.e. you should use
Also note that some configure options want to be pointed to a
configuration script and not to a directory, so you always need to read
the "./configure --help" output or the docs to check what you need to
pass. For instance, GDAL needs a reference to the gdal-config script, e.g.
--with-gdal=/usr/local/bin/gdal-config
HTH
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
