[Mapserver-users] Mapserver 3.6.5 -> 3.6.7
Stéphane RIFF
stephane.riff at cerene.fr
Mon Jan 26 03:07:34 EST 2004
I don't want to upgrade to 3.7 i wan't the 3.6.7 version... and i didn't
use templates and CGI all the application is in PHPMapscripts.
Swaminathan, Gayathri wrote:
>Stephane:
>Did anyone answer your question at all? Well if you are still wondering what went wrong, the "Migration guide" in Wiki explains this problem
>In order to enforce some security the previous CGI param has been changed. It will be only be accessible if you set DATAPATTERN <regex>.
>Also search for DATAPATTERN in archive, there are tons of information related to this problem
>HTH,
>Gayathri
>-----Original Message-----
>From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Stéphane RIFF
>Sent: Tuesday, January 20, 2004 3:23 AM
>To: mapserver
>Subject: [Mapserver-users] Mapserver 3.6.5 -> 3.6.7
>I use Postgres 7.2 and postgis 0.7.5, php 4.3.2....
>I tried to upgrade phpmapscript from 3.6.5 to 3.6.7 and my application
>doesn't work anymore.
>I get an error from postgresql :
> * Warning: MapServer Error in prep_DB(): Error executing POSTGIS
>DECLARE (the actual query) statement: 'DECLARE mycursor BINARY
>CURSOR FOR SELECT
>asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
>giscontourfrance WHERE the_geom && setSRID('BOX3D(42370.624
>1616618.5,1203176.624 2677218.5)'::BOX3D,
>find_srid('','giscontourfrance','the_geom') )'
>Postgresql reports the error ''
>But when i launch this query from phpPgAdmin :
> *SELECT
>find_srid('','giscontourfrance','the_geom') )*
>It works....
>Can someone point me to use mapserver 3.6.7 because i want to upgrade
>postgresql 7.2.4 to 7.3.*
>and only 3.6.7 support pgsql 7.3 ( I don't want to upgrade to mapserver
>4.0.1 now)
>Thanks
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
