[Mapserver-users] Mapserver 3.6.5 -> 3.6.7
Pericles S. Nacionales
nacional at cbs.umn.edu
Mon Jan 26 16:18:48 EST 2004
Stephane,
First try using the postgres account on your CONNECTIONSTRING and see if
it works. If it does, go back to your database and run GRANT SELECT ON
<TABLE_NAME> TO PUBLIC run it for every table you want to use in
MapServer (and perhaps to the SPATIAL_REF_SYS and the
GEOMETRY_COLUMNS). Now change your user back to what it was you used
before and see if it works.
If that still doesn't fix it, try one of these:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00331.html
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00334.html
Good luck!
-Perry N.
On Mon, 2004-01-26 at 02:07, Stéphane RIFF wrote:
> I don't want to upgrade to 3.7 i wan't the 3.6.7 version... and i didn't
> use templates and CGI all the application is in PHPMapscripts.
> Swaminathan, Gayathri wrote:
> >Stephane:
> >Did anyone answer your question at all? Well if you are still wondering what went wrong, the "Migration guide" in Wiki explains this problem
> >In order to enforce some security the previous CGI param has been changed. It will be only be accessible if you set DATAPATTERN <regex>.
> >Also search for DATAPATTERN in archive, there are tons of information related to this problem
> >HTH,
> >Gayathri
> >-----Original Message-----
> >From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Stéphane RIFF
> >Sent: Tuesday, January 20, 2004 3:23 AM
> >To: mapserver
> >Subject: [Mapserver-users] Mapserver 3.6.5 -> 3.6.7
> >I use Postgres 7.2 and postgis 0.7.5, php 4.3.2....
> >I tried to upgrade phpmapscript from 3.6.5 to 3.6.7 and my application
> >doesn't work anymore.
> >I get an error from postgresql :
> > * Warning: MapServer Error in prep_DB(): Error executing POSTGIS
> >DECLARE (the actual query) statement: 'DECLARE mycursor BINARY
> >CURSOR FOR SELECT
> >asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
> >giscontourfrance WHERE the_geom && setSRID('BOX3D(42370.624
> >1616618.5,1203176.624 2677218.5)'::BOX3D,
> >find_srid('','giscontourfrance','the_geom') )'
> >Postgresql reports the error ''
> >But when i launch this query from phpPgAdmin :
> > *SELECT
> >find_srid('','giscontourfrance','the_geom') )*
> >It works....
> >Can someone point me to use mapserver 3.6.7 because i want to upgrade
> >postgresql 7.2.4 to 7.3.*
> >and only 3.6.7 support pgsql 7.3 ( I don't want to upgrade to mapserver
> >4.0.1 now)
> >Thanks
> >_______________________________________________
> >Mapserver-users mailing list
> >Mapserver-users at lists.gis.umn.edu http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
"He's no geek.His tan's too good." -Benjamin Choate
