TR: [Mapserver-users] WMS server image black padding and aspect r
atio
Julien, Heryk
hjulien at nrcan.gc.ca
Mon Jan 26 08:12:39 EST 2004
Just a thought: It would also be a good idea if a WMS html getfeatureinfo
call could use the mapfile "WEB EMPTY" tag when no selections are made.
Cheers
Héryk
-----Message d'origine-----
De : Daniel Morissette [mailto:morissette at dmsolutions.ca]
Envoyé : Friday, January 23, 2004 5:11 PM
À : Eric Sokolowsky
Cc : mapserver-users at lists.gis.umn.edu
Objet : Re: [Mapserver-users] WMS server image black padding and aspect
ratio
Eric Sokolowsky wrote:
> I am running mapserver 4.0.1 but this aspect also appears with the
> version in CVS. I am using mapserver as a WMS server on a Red Hat Linux 9
> system. When I request an image that is not the same aspect ratio as
> the original image on the server, it seems that the image I get is
> not stretched so that it fills the entire frame. The aspect ratio of the
> original source is maintained and black bars either appear above and below
> or else on both sides, similar to the effect of watching widescreen movies
> on a regular TV. Is this the intended behavior, and if so, is there a way
> to turn it off?
The short answer is that MapServer doesn't support rendering maps with
different X and Y scales. This is one of the only issues with MapServer
before it passes all the OGC WMS tests.
For the long story, see the following thread in the archives:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00105.html
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
